Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-05-2004, 06:30 PM   #1
BigD904
CF Senior Member
BigD904's Avatar
Default Subwoofer Advice?
IÂ’m looking to install a sub in my 86 Vert, any ideas on what I should go with. I prefer non-powered but would do powered if it works out better. I have a pioneer deck and two 200W 4-Channel • 240W Bridged pioneer amps(GM-6000F ). I'm looking to run the 4 front speakers off of one amp and run the 2 6X9 rear speakers and a sub off the other amp. Does that sound like a smart idea? Or should I bridge the one amp with the 6X9's only and install a powered sub? What would be the best sub idea for the back of a 86 convertible? I'm not looking to wake up the neighborhood I'm just looking for a little more bang (better sound) than the 6X9's.
Thanks! :flag
[Modified by BigD904, 5:31 PM 6/5/2004]
[Modified by BigD904, 5:32 PM 6/5/2004]
BigD904 is offline   Reply With Quote
Old 06-06-2004, 02:02 AM   #2
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
Default Re: Subwoofer Advice? (BigD904)
Since you have two 4 channel amps what I would do is use 4 channels for the front four speakers. I would use the other 4 channel amp to run the 6X9s and one good sub. Run channels 1&2 to the 2 6X9s and bridge channels 3&4 to a single 4 ohm sub. (which can also be a dual 2 ohm or a dual 8 ohm if the sub is a DVC) Good luck
knewblewkorvette is offline   Reply With Quote
Old 06-06-2004, 02:52 PM   #3
BigD904
CF Senior Member
BigD904's Avatar
Default Re: Subwoofer Advice? (knewblewkorvette)
That sounds like a good idea. Thanks!
Any advice on what sub I should get?
Old 06-06-2004, 04:02 PM   #4
knewblewkorvette
CF Senior Member
There is a ton of good subs out in the car audio world. How much do you want to spend?
Old 06-06-2004, 04:26 PM   #5
BigD904
CF Senior Member
BigD904's Avatar
Around $300
Old 06-06-2004, 04:41 PM   #6
knewblewkorvette
CF Senior Member
http://www.cardomain.com/shoplist~b~...y~t~Subwoofers
Try the Infinity Kappa Perfect for $179. You might be able to find it even cheaper other than CarDomain. Spend the extra $ for a hi-quality box.
I have 3 in my vette
Old 06-06-2004, 08:38 PM   #7
BigD904
CF Senior Member
BigD904's Avatar
Any suggestions on a hi-quality box that would fit nice in the back of a convertible? and sound good? :flag
Old 06-06-2004, 11:11 PM   #8
knewblewkorvette
CF Senior Member
with that sub it is so simple.
You should be able to find one at a local stereo shop. Look for a 1 cubic foot enclosure made out of MDF. The MDF should be 3/4 or thicker. It should come with heavy duty speaker terminals and possibly be carpet covered. Expect to pay $50 but do NOT pay over $100 for a sealed single 12" box unless it is covered in gold
Old 06-06-2004, 11:53 PM   #9
BigD904
CF Senior Member
BigD904's Avatar
Thanks for all the advice. I have alot of $ researching to do.
:flag
Old 06-07-2004, 12:07 AM   #10
BigD904
CF Senior Member
BigD904's Avatar
One more question. Should I go with single or dual voice coil? and do you recommend I use a stiffening capacitor? I guess that was two more questions.
Old 06-07-2004, 12:21 AM   #11
knewblewkorvette
CF Senior Member
anytime
feel free to ask any and all questions
I need to do something at work
Old 06-07-2004, 12:34 AM   #12
knewblewkorvette
CF Senior Member
"a single 4 ohm sub. (which can also be a dual 2 ohm or a dual 8 ohm if the sub is a DVC) Good luck"
either is fine, as long as the final result is a four ohm load is what the amp sees
Do NOT go below four ohms or the Pioneer amp will send out smoke signals in distress.
Old 06-07-2004, 12:35 AM   #13
knewblewkorvette
CF Senior Member
you should not need a CAP as of now
Old 06-07-2004, 12:54 AM   #14
BigD904
CF Senior Member
BigD904's Avatar
Excellent! Thanks again for all the great advice. :flag
Old 06-07-2004, 01:24 AM   #15
Joer350
CF Senior Member
Send a message via AIM to Joer350
if you don't want to pay as much you can always run the mtx 4000 series these are good and only about $50 each. I had 2 10's and my friends tought I had 2 12's and it would set off alarms that was with a bazooka amp that would do 500rms and a custom box I built for them. But don't put an amp that has a higher rating
Another good quality are the alpines. But the most important thing is the box it must be good one and meet the subs space requirements. You may have the most expensive sub but if the box is crappy it won't sound like it should!
Joer350 is offline   Reply With Quote
Old 06-07-2004, 01:39 AM   #16
BigD904
CF Senior Member
BigD904's Avatar
Default Re: Subwoofer Advice? (Joer350)
Thanks! I'll check them out.
Old 06-07-2004, 11:07 PM   #17
BigD904
CF Senior Member
BigD904's Avatar
I just measured the storage space behind the seats and it doesn't look like there is much room when the top is down. I only have about 8 inches of height with the top down. The top takes up most of the space. Any convertible owners install a sub? what did you use? Whats my options?
Thanks! :flag
Old 06-08-2004, 07:57 PM   #18
knewblewkorvette
CF Senior Member
I won't let you down
Check these out
http://www.jlaudio.com/subwoofers/6w0.html
Buy two 8 ohm woofers or four 4 ohm woofers. Get a custom box and enjoy.
I would also consider Bazooka for those tight spots
http://www.ikesound.com/category-category_id/117
Old 06-08-2004, 11:55 PM   #19
BigD904
CF Senior Member
BigD904's Avatar
Thanks! I think those JL Audio's might work. Now I just have to find out where to buy them. Have you ever heard JL Audio? how do they sound? They look like quality subs and enclosures. I appreciate all your advice
Anybody have any pics. of subs in a convertible. Just looking for some custom box ideas. :flag
Old 06-09-2004, 07:43 AM   #20
knewblewkorvette
CF Senior Member
I have used JL subs since 1991. I had 9 of them up til a month ago when four 15" were stolen :mad . I still have five 18" JLs and they are serious subs
Reload this Page Subwoofer Advice?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Advice on a sound system. LuckyKid19 Audio/Electronics 27 06-28-2004 06:29 PM
KICKER Solo-Baric L5 subwoofer 85 Stalker Audio/Electronics 74 06-15-2004 02:41 PM
Changing stereo system. Need advice. singrav C4 General Discussion 18 08-27-2003 11:22 AM
2 or 1 8inch Subwoofer(s)? Light84vette Audio/Electronics 33 03-13-2003 02:58 AM
Subwoofer advice needed. lofarris Audio/Electronics 12 10-16-2002 02:28 PM
Want to replace C5 Factory unit with MP3 player - advice needed BAD. Venger Audio/Electronics 20 07-17-2002 01:46 AM
Advice on System tkemory Audio/Electronics 36 04-05-2002 10:50 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
