Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-04-2004, 06:53 PM   #1
TexasAg98
CF Senior Member
Cruise-In II Veteran
TexasAg98's Avatar
Send a message via MSN to TexasAg98 Send a message via Yahoo to TexasAg98
Default My C5 gauge and door lights won't turn off!!! Help...
I'm having some extreme problems with my C5 right now. I was originally blaming it on the battery, which I've taken to Interstate Battery twice because it was dead, they recharged it and told me nothing was wrong. Instead of insisting, I believed them and put the battery back in the car. Before the battery gave out the first time, the passenger door is completely dead. It won't lock/unlock, and the window won't roll up/down.
So, I take it for a drive and the radio turns off, and I get all sorts of errors (tires, low fuel, reduced power, etc) on the DIC. When I get home, I turn the car off and go inside and watch a movie. When I go back outside I see the gauge lights are still on. After opening then closing the door and waiting, it goes off, but the door lights are still on!
This is what has been killing the battery. Sounds like a loose connection somewhere, am I right?
Thanks.
TexasAg98 is offline   Reply With Quote
Old 06-05-2004, 12:24 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
Default Re: My C5 gauge and door lights won't turn off!!! Help... (TexasAg98)
you have a problem... and fixing it will require:
1) Time, lots of it
2) a test light
3) a good volt meter
4) More time
5) tools to take the interior apart (more than likely)
6) Did I mention time?
This is going to be a bitch to track down... I am betting you have either a bad ground somewhere, a bad connector or a bad component. Figuring out what is going to be the trick.
First off? Make sure the battery terminals and main chassis grounds are good, clean and tight.
I would then get a copy of your vintages' Helms Manual and trouble shoot all grounds. Make sure everything is good and snug. All you need is one corroded connector and you are out of business.
And this will take time... be patient... but it will more than likely cause you some serious annoyance before it's done.
bogus is offline   Reply With Quote
Old 06-06-2004, 02:09 AM   #3
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
Default Re: My C5 gauge and door lights won't turn off!!! Help... (bogus)
Take the whole car to an Autozone or Advanced Auto and have them check the system while it is in the car. This is a free service. Make them use a gound other than the neg terminal. I'm suspecting a bad ground, (God forbid a GM battery leaked on your vette computer ), could be an alt problem but it really doesn't sound like it. Corvettes do NOT like a weak battery
knewblewkorvette is offline   Reply With Quote
Old 06-12-2004, 11:35 AM   #4
TexasAg98
CF Senior Member
TexasAg98's Avatar
Thanks guys. Knowing this, I'm having it checked out soon (hopefully today) and I'll post back here to see what it was.
Old 06-16-2004, 04:04 PM   #5
TexasAg98
CF Senior Member
TexasAg98's Avatar
Well, the problem traced back to the passenger door module. We were getting a hot ground wire in there somewhere.
Taking that harness apart, redoing the sloppy aftermarket alarm work, and taping it back up worked!
We'll see for how long. I have my fingers crossed.
Old 06-16-2004, 05:27 PM   #6
leolufse
CF Senior Member
leolufse's Avatar
Send a message via AIM to leolufse
You got lucky. Glad to hear it worked out for you.
leolufse is offline   Reply With Quote
Reload this Page My C5 gauge and door lights won't turn off!!! Help...
Tags
c5, corvette, lights, turn, wont
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
? about buying a C5 gmintimidator C5 General 10 03-21-2005 02:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
