Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-14-2004, 10:14 PM   #1
Brtheez
CF Senior Member
Default Engine Noise in Speakers
I have a 1989 convertible. I am getting serious engine noise in the speakers. When the engine is off there is a slight hissing from one of the rear speakers. Think the Bose amp is bad because speaker doesn't come on right away when radio is on. As far as the engine noise in the speakers, it's driving up the wall. Any ideas on what it could be?
Brtheez is offline   Reply With Quote
Old 04-15-2004, 09:16 AM   #2
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
Default Re: Engine Noise in Speakers (Brtheez)
Is your system stock or aftermarket?
EatRice is offline   Reply With Quote
Old 04-15-2004, 10:22 PM   #3
Brtheez
CF Senior Member
Default Re: Engine Noise in Speakers (EatRice)
It's a stock Delco Bose system with bose speakers.
Old 04-16-2004, 01:29 AM   #4
EatRice
CF Senior Member
EatRice's Avatar
Then something changed in the system. Either a ground path or a bad component. Knowing the year of your car and BOSE it is proably one of the amps. I would take one out at a time till the noise goes out of the others.
Old 04-16-2004, 11:36 AM   #5
ericdwong
CF Senior Member
ericdwong's Avatar
Is it a whine like a dremel/dentist drill or more of a ticking? What kinda plug wires you using? I heard some have some EMI/RFI issues....but i'd check the OEM ground of the radio/amps and the power antenna, make sure they are still clean. A service manual should tell where they are.
[Modified by eRiCdWoNg, 11:37 AM 4/16/2004]
ericdwong is online now   Reply With Quote
Old 04-16-2004, 01:12 PM   #6
bogus
CF Senior Member
Send a message via Yahoo to bogus
Default Re: Engine Noise in Speakers (eRiCdWoNg)
It's also a sign the amps are failing.
bogus is offline   Reply With Quote
Old 04-16-2004, 08:57 PM   #7
Brtheez
CF Senior Member
The spark plug wires are original I believe. It has 64,000 miles on it. What does EMI/RFI mean. What if someone put cheap plugs in it? Oh and the sound is a definite whine like a dremel. It coincides with the engine idle and RPM.
Old 04-16-2004, 11:46 PM   #8
EatRice
CF Senior Member
EatRice's Avatar
I highly doubt spark plugs are going to do it. The whine is a direct result of RPM. It is a noise generated by the alternator. Your problem is going to lie in the audio system and is most likely in one of the amplifiers. Either take out the amplifiers yourself one at a time till the noise is gone or take it to a qualified car audio shop.
Old 04-19-2004, 09:31 PM   #9
Brtheez
CF Senior Member
I will do that. Thanks a lot for the advice.
Old 10-18-2004, 11:02 PM   #10
corvette1989bham
CF Senior Member
corvette1989bham's Avatar
Did you ever get the problem fixed?
corvette1989bham is offline   Reply With Quote
Reload this Page Engine Noise in Speakers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Boston Acoustics Z6 and Z5 Speakers sliderhss Audio/Electronics 10 04-30-2004 09:26 AM
Engine Noise in Speakers Eric 96 C4 General Discussion 13 09-06-2002 12:51 PM
Ignition noise in system??? DngrZne Audio/Electronics 12 04-12-2002 06:09 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
