Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-14-2004, 07:27 PM   #1
Last Ride
CF Senior Member
Last Ride's Avatar
Send a message via AIM to Last Ride
Default C4 System: Fronts?
Hey all--
Well, it looks like I am going to be venturing into the C4 arena soon. I have stereo pieces ready to go into the car, but I need some additional advice. The headunit I will run is an Eclipse 8443. I also have a set of CDT Audio HD62-ef's. Originally (on my old car), I was going to run the CDT's in the front door panel and do two 8" subs in the rear. I am now hearing that the 6.5" speakers will not fit well in the front doors. Is this true? If so, is there a set of CDT's that will fit that are comparable to the HD62-ef? If I go with a smaller CDT set for the front doors, I might forego the subs and just put the 6.5" in the rear. I am not looking for booming sound, but I want it to sound nice. Finally, I have been looking at 4-channel amps for the latter that put out 100-125 watts per channel. Does anyone have any recommendations? Thanks as always for the help.
Last Ride is offline   Reply With Quote
Old 04-14-2004, 10:55 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
Default Re: C4 System: Fronts? (Last Ride)
door speaker installs are much easier than installing a 6.5" in the rocker panel (as installed in 90-96 MY).
You will need a 160 hz (think that's it) notch filter. that will lower the response at that frequency... namely, because the door amplified that frequency! this information is from Kale.
I am a big fan of the JL Audio Slash series amps...
bogus is offline   Reply With Quote
Reload this Page C4 System: Fronts?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Audio FAQ bogus Audio/Electronics 49 01-31-2012 04:41 PM
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
C4 '89 Bose Replacement Project (advice pls) Stonecutter908 Audio/Electronics 9 10-14-2004 04:47 PM
sound system options for late C4 aeronautica86 Audio/Electronics 15 05-06-2004 05:20 PM
Front Rear and Subs in Rear compartments of C4's Spike13 Audio/Electronics 21 02-29-2004 12:39 AM
C4 weight reducation MongooseLT4 C4 Tech/Performance 32 11-26-2003 10:56 PM
Homemade C4 ramps/no pictures? fixvet C4 General Discussion 18 05-09-2002 07:28 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
