03-08-2004, 01:05 PM
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Re: Quick Amp Power Question (bart15)
If your power wire is at least 8-gauge or larger then you really should just drill a hole through the firewall just to the left and below the power break booster (that big round disk that the master cylinder is bolted to). There is a clear spot there on the firewall both inside the engine compartment and inside the car.
