Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-07-2004, 04:11 PM   #1
billwineberg
CF Senior Member
Send a message via ICQ to billwineberg Send a message via AIM to billwineberg
Default Please HELP asap, need help with what gauge wiring ???
have Alpine 9813 head unit,
General Specifications
RMS Power Output: 27x4 Watts
Maximum Power: 60x4 Watts
DIN: 1
CD-R/CD-RW Compatible
1a) need to know best gauge power wire to run to the head unit as it says to run off battery.
1b) and should i use a circuit breaker, if so what kind?
and where should i install it?
2) need to know best gauge wires to run to 6.5 speakers in doors. I MAY ADD A 75w amp later.
3) need to know best gauge wires to run to 50w amp that will run sub(s)
4) need to know best gauge wires to run from sub amp to Subs.
ANY OTHER WIRING HELP, TIPS, or advice will be appreciated,
THANKS.
billwineberg is offline   Reply With Quote
Old 03-07-2004, 05:04 PM   #2
TheWacoKid
CF Senior Member
Cruise-In II Veteran
Cruise-In III Veteran
Send a message via AIM to TheWacoKid
Default Re: Please HELP asap, need help with what gauge wiring ??? (billwineberg)
1a: 8 to 10 guage will be fine.
1b: Yes you should use a fuse on the power wire in addition to the main fuse in the deck itself. Install it 8-12 inches from the battery, I would use double the fuse rating of the one in the deck(but it really doesn't matter as long as it is at least the same as the deck fuse, but not bigger than 50 amps).
2: Anything from 14 gauge to 18 will be fine.
3: 50w amp seems a little small...but there is no reason not to run 4-8 gauge wire to leave room for upgrades down the road.
4: 10 to 14 gauge will work.
That help? :cheers:
[Modified by TheWacoKid, 4:04 PM 3/7/2004]
TheWacoKid is offline   Reply With Quote
Old 03-07-2004, 05:05 PM   #3
Kale
CF Senior Member
Kale's Avatar
10 gauge should be fine
Get a walmart 10 gauge kit, it hasa built in fuse holder.
16 Gauge will be fine. I buy 50 foot rolls of 16 at Walmart for $7
10 gauge is fine. But I'd GO with 8 gauge since you plan to get a bigger amp some day. Another wamlart kit.
16 gauge is fine for 50 watts.
Copper is as copper does. Dont let anyone talk you into expensive wires.
THANKS.
No Problem.
Kale is offline   Reply With Quote
Old 03-07-2004, 06:09 PM   #4
billwineberg
CF Senior Member
Default Re: Please HELP asap, need help with what gauge wiring ??? (Kale)
thanks guys i'll guess be heading to WallyWorld soon...
Kale, I agree on the copper is copper thing the expensive install kits I saw in the electronics stores are why I asked for recommended gauge sizes so i could source wires other than in monster kit form.
OH, I almost forgot... RCA CONNECTORS
GOLD plated or NOT???
What kind to get and where to get are best???
THANKS!
Thanks!
Old 03-07-2004, 06:10 PM   #5
Kale
CF Senior Member
Kale's Avatar
Just get good sturdy cables. I like thick cables so they aren't pinched easily. I wouldnt spend the extra money on gold cables.
Old 03-07-2004, 06:17 PM   #6
billwineberg
CF Senior Member
is this a good kit?
and good price???
http://www.walmart.com/catalog/product.gsp?cat=3947&dept=3944&product_i d=1863080&path=0%3A3944%3A3947%3A96490
Old 03-07-2004, 06:33 PM   #7
Kale
CF Senior Member
Kale's Avatar
yes
Reload this Page Please HELP asap, need help with what gauge wiring ???
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
