Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-05-2004, 09:59 PM   #1
TheWacoKid
CF Senior Member
Cruise-In II Veteran
Cruise-In III Veteran
Send a message via AIM to TheWacoKid
Default Response curves...
Which would you prefer to have?
[Modified by TheWacoKid, 8:59 PM 3/5/2004]
TheWacoKid is offline   Reply With Quote
Old 03-05-2004, 10:06 PM   #2
Kale
CF Senior Member
Kale's Avatar
Default Re: Response curves... (TheWacoKid)
green for sure.
Kale is offline   Reply With Quote
Old 03-05-2004, 10:17 PM   #3
TheWacoKid
CF Senior Member
Default Re: Response curves... (Kale)
Quote:
green for sure.
Why is that? I don't listen to anything that has output below 15 hz or so, though the green curve is smoother...in car it isn't going to be very smooth anyway with my cars transfer fuction added in. :confused:
Old 03-05-2004, 10:23 PM   #4
Kale
CF Senior Member
Kale's Avatar
yellow will sound peaky and nasty. of course, if thats your goal...
Old 03-06-2004, 01:17 AM   #5
TheWacoKid
CF Senior Member
Lol...everything sounds peaky in my car no matter how smooth the origional curve is...
Besides...rock/metal/techno isn't exactly demanding upon the entire bass range. The Pirates of the Carribean soundtrack still sounds awesome...as does E.S. Posthumus and Requiem for a Dream. The yellow curve adds a whole lot of kick to the drums/beats.
Meh...to each his own. :cheers:
Old 03-06-2004, 01:28 PM   #6
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
Both curves are nice...yellow would be more likely the way to go. How would it sound peaky? It has a very nice curve with a gentle slope. If anything the green one would be on the weak side for the average person look for a sub.
EatRice is offline   Reply With Quote
Old 03-06-2004, 04:23 PM   #7
TheWacoKid
CF Senior Member
Default Re: Response curves... (EatRice)
That is exactly it...I don't think it sounds peaky at all...it has a very smooth transition from 150-20 hz in a sweep. The green curve when swept from 150-20 hz felt a little weak in the 45-60 hz range.
Old 03-06-2004, 04:29 PM   #8
Kale
CF Senior Member
Kale's Avatar
Well, I tend to look for SQ over SPL out of a sub - thats why my choice for the flatter curve. The car does enough bad things to frequencies without exaggerating the problem. 'Course if you just want a boomcar this doesnt apply to you.
Old 03-06-2004, 04:51 PM   #9
TheWacoKid
CF Senior Member
It isn't a boomcar...I spent 3 days making it not loud outside the car...but I do like to be able to blur my vision when I crank it...so SQL it is for me. If that means I have to deal with an exagerated low end...so be it. :yesnod: :cheers:
Old 03-06-2004, 05:20 PM   #10
EatRice
CF Senior Member
EatRice's Avatar
Then on the flip side if the car has a drop in the low frequencys...such as the Honda Accord 4 door 1990 body style. You will need to build a box that has a high bass response so equals out inside the vechicle. The information that a computer program provides is only a basis to go by. Ultimately you need an in car measurement.
Old 03-06-2004, 05:27 PM   #11
Kale
CF Senior Member
Kale's Avatar
Definately.
Old 03-06-2004, 05:33 PM   #12
TheWacoKid
CF Senior Member
Quote:
Definately.
something I don't have or have the money to have done at a shop. :lol:
This is what I know about my car's transfer function(by ear):
I have a pretty big boost around 70 hz, then a dip from 35-60, and then a big bump from 35 on down to 5 hz or so. When I had my subs sealed I could hit 5 hz with ease...with the ported box I can't anymore, but from 15-30 hz is much stronger than the sealed box...and from 45-60 hits much much harder than it ever did before.
That peak seems to smooth out really well...I thought it would sound like crap at first also.
Old 03-06-2004, 08:45 PM   #13
gcrouse
CF Senior Member
gcrouse's Avatar
How would anyone think the yellow curve sounds "peaky and nasty"???
Assuming he crosses the sub at 80 Hz or so, you're looking at a whole 1dB "peak" at 52Hz over what it does at 80Hz.
gcrouse is offline   Reply With Quote
Old 03-06-2004, 11:11 PM   #14
Kale
CF Senior Member
Kale's Avatar
Default Re: Response curves... (gcrouse)
Youre right, i didnt notice they were so close together. But still, I'd go with the flatter one.
Old 03-07-2004, 02:32 PM   #15
TheWacoKid
CF Senior Member
85 hz.
Reload this Page Response curves...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 racers: I got suspension questions. HJV11 Autocrossing & Roadracing 14 07-19-2005 02:32 PM
Don't let this happen to you Andy@AandACorvette C5 Tech 158 07-13-2005 12:33 AM
Drive by wire? Vet C6 Corvette General Discussion 24 03-14-2005 03:09 AM
DiabloSport Predator Pre-Order Special Pricing Extended! RWTD C5 Tech 591 09-20-2004 06:15 PM
Just ordered some bad-azz tweets!! Kale Audio/Electronics 21 02-08-2003 09:54 PM
What brand headunit is in your Corvette? CentralCoaster Audio/Electronics 34 12-30-2002 03:43 PM
What's wrong with Bose?? Jimbo93 C4 Tech/Performance 34 11-24-2002 10:01 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
