Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-05-2004, 05:41 PM   #1
vmspionage
CF Senior Member
vmspionage's Avatar
Send a message via AIM to vmspionage
Default C5 help: where to mount more amps
:seeya
I had a question for the guys out there with more than a couple of amps. I currently have a 3 speaker enclosure filled with 10" RF Punch DVC subs. Right now the DVCs are jumpered together, with all 3 speakers run in parallel. Thats connected to a RF Punch 800a2 bridged down to 1 channel. The thing is these speakers can handle 1000W each, and I'm only putting about 250 to each right now. What I want to do is install 2 more Punch 800a2's, the only problem is I'm trying to find a place for the amps and the capacitors that looks good.
The only requirments I have are that it look good and not get in the way of the targa when it's off. Thanks for your ideas!!!! :cheers:
-Jeff
Here are some pics of my current setup...
vmspionage is offline   Reply With Quote
Old 03-10-2004, 11:33 PM   #2
msuc5vette
CF Senior Member
Default Re: C5 help: where to mount more amps (vmspionage)
Your amp mount looks awesome!
There is a lot of room above the all of the rear compartments before you interfere with the top storage.
I'm not sure on the exact dimensions of the RF amplifiers, but if I'm remembering correctly those side things come off making the amp smaller right?
Could you build a small carpted frame to go around each of the extra two amps an put over the side compartments replacing the covers with the amps?
If the size happens to work I think that would look pretty cool and take up minimal extra space.
Another option would be to stand all three vertically and have them in the center well. You could kinda stadium tier them so they look cool.
I know you can relocate the changer to one of the side wells to add space in the center.
msuc5vette is offline   Reply With Quote
Old 03-12-2004, 11:10 AM   #3
vmspionage
CF Senior Member
vmspionage's Avatar
Default Re: C5 help: where to mount more amps (msuc5vette)
Thanks for the complements! :cool: Yea the sides of the amps come off but they do a good job of hiding the connections, although if it came down to it I could always remove those and build a smaller frame to hide the wires. I honestly never thought about stacking the amps and that's actually a really good idea now that you mention it, although I'd have to install some fans to circulate the air over the heat sinks. The changer isn't hooked up regardless so I can pull that out and get a little more room, and while I'm at it I was thinking about relocating the capacitors to one of the side compartments.
Thanks again for the ideas. I'll be sure to post some more pics when it's done :cheers:
:seeya Jeff
Reload this Page C5 help: where to mount more amps
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C5 Bose upgrade wiring notes 99HT Audio/Electronics 11 10-08-2011 05:45 PM
C5 Bose Upgrade Info 99HT Audio/Electronics 18 08-16-2004 04:02 AM
Recommedations for a new C5 stereo...? aurik Audio/Electronics 19 11-21-2002 01:36 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
