Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-05-2004, 05:12 PM   #1
74-Roadster
CF Senior Member
St. Jude Donor '06
Father & Son St. Jude Donor '09
74-Roadster's Avatar
Default Need help - Removing and mounting external crossovers
I'm replacing my rear speakers this weekend (new ones finally arriving today). The aftermarkets that are installed right now (one cone is cracked due to poor install) have the crossovers glued to the inner fender wells.
Questions:
What type of glue was used? I think a shop did the install.
How do I remove them without damaging the fender well?
My new speakers also have an external crossover, what glue should I use to mount them?
Thanks! :cheers:
74-Roadster is offline   Reply With Quote
Old 03-06-2004, 10:39 AM   #2
74-Roadster
CF Senior Member
St. Jude Donor '06
Default Re: Need help - Removing and mounting external crossovers (74-Roadster)
ttt
Old 03-06-2004, 01:21 PM   #3
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
what glue was used it anybodys guess. Alot of shops use hot glue and silicone but it could be something else. If it is glues directly to a body panel I would either leave it alone or try twisting it clockwise or counterclockwise. Doing that should not harm your body panel.Prying on it most likely will.
For the new crossover I would not glue it. I would use a dbl sided tape like something from 3M.Most automotive parts stores carry a 3M tape in the body section. It is gray or white with a red covering. That tape will hold forever but still come off if you want it to.
Good luck
EatRice is offline   Reply With Quote
Old 03-06-2004, 01:42 PM   #4
74-Roadster
CF Senior Member
St. Jude Donor '06
Default Re: Need help - Removing and mounting external crossovers (EatRice)
Thanks for the tip . . . Tape sounds like the plan! :thumbs:
If the existing ones won't budge, I'm going to try and heat them up some to see if I can soften the glue.
Reload this Page Need help - Removing and mounting external crossovers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
