Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-27-2004, 08:57 PM   #1
bart15
CF Senior Member
bart15's Avatar
Default C4 Door Speaker Install
I am tearing apart my doors right now, with the notion that I am going to install some 6.5" drivers there...
The problem is I can't get the inner section of the door out (the aluminum inner bracket that holds everything from the door handle hardware to wiring, etc.).
Does anyone out there know of the secret to ge this part out. I've looked in my shop manual and chilton manual and I am not getting what I need. I'm about to unleash the BFH on the project. :banghead:
Thanks for the help.
:seeya
bart15 is offline   Reply With Quote
Old 01-28-2004, 03:08 AM   #2
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Default Re: C4 Door Speaker Install (bart15)
I usually need a SFH to get it back in, but getting it out is usually no problem.
On my 94 it goes like this:
In addition to the several hex-head screws around the edge, there's a phillips screw towards the back. Also remove the lower bolt on the rear window-stop, and it helps to loosen the top bolt on the stop (might want to mark it so you get it back in the same place.)
Now you have to disconnect the two rods inside (door lock and door handle) in several places. Now that everything is loose, move the panel down in the door until you can get the top edge through the opening. Then you have to unplug the wiring from the door lock solenoid.
This is from memory, so I may have forgotten something...
Vis Croceus is offline   Reply With Quote
Old 01-28-2004, 06:31 PM   #3
bart15
CF Senior Member
bart15's Avatar
Default Re: C4 Door Speaker Install (steve9899)
I was wondering if I'd need to play with the window bracket... I hate it that it is so cold here now. I can't stand working on it even in the garage. I miss my SoCal days.
Thanks for the assist!
:seeya
Reload this Page C4 Door Speaker Install
Tags
c4, corvette, door, install, speaker
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Audio FAQ bogus Audio/Electronics 49 01-31-2012 04:41 PM
Anybody have pic's of Stereo systems Installed on a C4? Bevo C4 Tech/Performance 24 01-20-2004 08:05 PM
It began easy enough...new speakers in C4 Goody Audio/Electronics 22 10-03-2003 08:29 AM
stealth C4 sub install bart15 Audio/Electronics 12 08-19-2003 11:44 AM
Sub for a c4? where to install? dmalhi1 Audio/Electronics 19 04-14-2002 02:17 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
