Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-26-2003, 02:15 AM   #1
Cory00
CF Senior Member
Cory00's Avatar
Send a message via AIM to Cory00
Default 2 new rockford amps and a few ?s
well i just want to say ya'll cant bust my balls any more for my crappy amps my parents got me 2 900 watt mono rockford amps and 2 12' infinitys and im lovin it now i know why you guys dont like pyrmids and i dont blame you
ok any ways i have some ?s maby stupid but bare with me
1st i have every thing hooked up right and it quakes but it skips my cd player real bad can i out line the unit in that dynomatt stuff
2nd my hatch/gastank lid/licence plate rattle real bad also what can i do to stop that
3rd where is the best place that i can put the subs to get the best boom hitting of the glass or the rear
thanks for the help guys hope every one had a good xmas :cheers:
Cory00 is offline   Reply With Quote
Old 12-26-2003, 02:19 AM   #2
KDuniverse
CF Senior Member
KDuniverse's Avatar
Send a message via AIM to KDuniverse
Default Re: 2 new rockford amps and a few ?s (Cory00)
everytime I read one of your posts, it hurts my head
KDuniverse is offline   Reply With Quote
Old 12-26-2003, 02:22 AM   #3
Kale
CF Senior Member
Kale's Avatar
Backstrap.
Foam insulation tape around the rim
Facing the rear wall, 6" from it.
Are they the Rockfords rated at 900 RMS or 900 Max watts?
if its 900 rms, you'd better consider running 0 gauge wire back to your fused distribution block. I'd hate to see you burn your car down.
:eek:
Kale is offline   Reply With Quote
Old 12-26-2003, 02:25 AM   #4
Cory00
CF Senior Member
Cory00's Avatar
Default Re: 2 new rockford amps and a few ?s (Kale)
thanks kale
its 900 max power
also what do you mean by a backstrap for the cd player
thanks for the help
[Modified by Cory00, 1:25 AM 12/26/2003]
Old 12-26-2003, 02:38 AM   #5
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
A backstrap is a piece of metal tha has holes in it. Usually your radio will come with one or you can buy one from a local hardware store. What he means by using the backstrap is that you need to mount the radio in a sturdy fashion. If you have it in a regular dash kit that is not sturdy enough. Most standard dash kits do not offer support to the rear of the radio. You need to make the radio mount very strong. That will help alot if not stop the skipping all together. If you are really unsure about doing that you can always take a 30 minute drive to my place in Wesley Chapel and I will help you out with it. One other thing if you have to buy the backstrap is it usually called plumbers strap at home depot and it will come rolled up. Just straighten it out and use a short bolt in the back of your radio to secure it. Do not put a long bolt, longer than 1/4" into the radio because it could damage the electronics.
[Modified by EatRice, 1:52 AM 12/26/2003]
EatRice is offline   Reply With Quote
Old 12-26-2003, 02:46 AM   #6
Kale
CF Senior Member
Kale's Avatar
ok so both amps are probably running around 800-900 RMS watts together.. should be OK with 4 gauge wire, but no less.
Old 12-26-2003, 10:26 PM   #7
Cory00
CF Senior Member
Cory00's Avatar
hey guys i whent to circuit city today to have a backstrap put on and i was talkin to the guy that always does my installs there, and he told me that a backstap thing wont help that much is this true :confused:
well any way im still going to get it beacuse its free, so what do i have to loose
i hop this thing helps, i hate listing to the raido but its good because the raido does not skip
:cheers:
Old 12-26-2003, 10:33 PM   #8
EatRice
CF Senior Member
EatRice's Avatar
Cory.....I have never installed a backstrap and have it not fix the problem. I have installed ALOT of radios. I do not want to diss your installer but it is a Circuit City policy to hire inexperienced installers so that they can be trained in the Circuit City ways. The company believes it is easier to train a inexperienced person than it is to brake bad habits of a veteran installer. The major thing CC calls a bad habit it the use of crimp connectors in a car. They solder all their connections. That sentence could turn this into a long thread. Either way you are correct to have it done since it is free. As long as it is installed properly it should greatly reduce your skipping if not totally remove it. Let us know how it works.
Old 12-29-2003, 12:11 AM   #9
Cory00
CF Senior Member
Cory00's Avatar
Default Re: 2 new rockford amps and a few ?s (EatRice)
i whent to cc and the guy looked at it , took the cdplayer out and hes like well it wont help you one bit. :mad holy crap why not i now hate cc
Old 12-29-2003, 10:48 AM   #10
EatRice
CF Senior Member
EatRice's Avatar
I will do it for you if you want. Send me an IM or email for details but I live only a few miles off of I75 on SR 54.
Old 12-29-2003, 11:07 AM   #11
leolufse
CF Senior Member
leolufse's Avatar
Send a message via AIM to leolufse
Default Re: 2 new rockford amps and a few ?s (KDuniverse)
:lolg:
leolufse is offline   Reply With Quote
Old 01-01-2004, 09:31 PM   #12
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
knewblewkorvette's Avatar
you are such a nice guy :thumbs:
knewblewkorvette is offline   Reply With Quote
Reload this Page 2 new rockford amps and a few ?s
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stereo Install done (pics..dial-up death) vettfixr C3 Tech/Performance 32 03-16-2010 05:46 PM
** WINTER SALE ** '98 Pace Car, 6-spd, 16k, some mods, extended warranty, $33,990 98pace#870 C5 Corvettes for Sale 13 11-17-2002 04:09 PM
FS: 98 Pace Car, 15k, intake/exhaust mods, new tires, warranty, custom stereo, $35,900 98pace#870 C5 Corvettes for Sale 16 07-31-2002 05:06 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
