Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-25-2003, 03:27 PM   #1
Kehrer923
CF Senior Member
Send a message via AIM to Kehrer923
Default Trying to pick a new sub
I have a 10" w3 Jl right now and I only have 200watts rms on it. But it seems like my amp is giving it more than it can take and I would really like a louder sub. Any ideas...I have thought about trying a Kicker solo baric L7, I would use a w7 but i know i dont have enough power.
Kehrer923 is offline   Reply With Quote
Old 12-25-2003, 04:17 PM   #2
Kale
CF Senior Member
Kale's Avatar
Default Re: Trying to pick a new sub (Kehrer923)
200 watts isnt more than it can take... not at all... what problem are you having with it?
with 200 watts you arent just giong to swap subs and get louder.. i mean.. you can increase displacement and gain a *little* volume (by going to a 12 for example)
or you could Port the sucker, and gain at least 3 decibel.
My IDMAX went from "nice moderate bass" in a sealed box to "vision blurring, body panel flexing, bone shaking bass" in a ported box.
(mostly from the low end gain)
[Modified by Kale, 12:42 PM 12/25/2003]
Kale is offline   Reply With Quote
Old 12-25-2003, 05:43 PM   #3
Kehrer923
CF Senior Member
Default Re: Trying to pick a new sub (Kale)
I have it sealed in the storage compartment. I dont think I can port that.. :confused: It seems like it gets really disorted when i turn the bass all the way up like it has to much power
Old 12-25-2003, 06:29 PM   #4
Kale
CF Senior Member
Kale's Avatar
if you overpower it, and run it into Mechanical Distortion, you'd likely have smoked it by now.
it usually gets distorted because it doesnt have ENOUGH power and you're just sending clipping to it.
could be that you have your gains set too high, and you're clipping the living snot out of the subwoofer. (real easy to do when you expect a lot out of a sub)
also the storage compartment is a terrible place for it. you can make it MUCH louder if you have it in a box facing the rear wall.
but if you say "turn the bass all the way up"... do you mean the sub volume control, or an actual "BASS" control? Bass controls do nothing but add clipping/distortion. ..potentially damaging your sub by causing thermal failure. (Melting it)
[Modified by Kale, 2:32 PM 12/25/2003]
Old 12-25-2003, 10:43 PM   #5
Kehrer923
CF Senior Member
I mean turn it up, by turn the sub control up on my d900. Changing the location of the sub is not an option. How would i change my gain? My amp is a 5 channel and the sub is on the specific sub 5th channel. Do you think i coul build a box behind the sub that would fit in the storage compartment
Old 12-25-2003, 10:47 PM   #6
Kale
CF Senior Member
Kale's Avatar
wait.. how big of a box is this sub in? is it perfectly sealed? if its not air tight, bad things happen.
Old 12-26-2003, 02:58 AM   #7
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
The gain is dial control on your amplifier. It will indicate that it is for the 5th channel and you might need a small screw driver to change it. What is your crossover set at?
What kind of bad things happen to an enclosure that is not air tight? Many subwoofers just because of the contruction of their surround will not allow a perfectly sealed enclosure.
EatRice is offline   Reply With Quote
Old 12-26-2003, 03:34 AM   #8
Kale
CF Senior Member
Kale's Avatar
Default Re: Trying to pick a new sub (EatRice)
distortion, for example. Bad enough leak, you could actually damage a subwoofer.
Old 12-26-2003, 04:13 AM   #9
Kehrer923
CF Senior Member
I dynamatted the entire inside I really dont know if it is airtight or not.
Old 12-26-2003, 10:02 AM   #10
EatRice
CF Senior Member
EatRice's Avatar
Kehrer........you dynomatted the inside of the enclosure? I bet that took a little time...lol. That is will help with the bass response and SQ but not with you any of your rattles. It was a good idea to that. In the future what I have found to work the best is spray on sound deadner. Goes on very easily and bonds tighter than an adhesive backed dynomat will.
I have never heard of a woofer being damaged by an air leak. I tried looking it up in The Loudspeaker Design Cookbook and a couple of others but they made no mention of actual damage.
Old 12-26-2003, 01:01 PM   #11
Kale
CF Senior Member
Kale's Avatar
Same principal as a ported box.. basically it can be damaged by over excursion, if yourerunning enough power. it would ha ve to be a significant leak tho..
Old 12-26-2003, 02:23 PM   #12
EatRice
CF Senior Member
EatRice's Avatar
That is not a leak...that is a gaping hole in the enclosure lol
Old 12-26-2003, 07:46 PM   #13
Kale
CF Senior Member
Kale's Avatar
you should see some of the home made boxes I've seen.. even "profesionally done ones" have had 1/4" gap at one end on the board. :eek:
Old 12-27-2003, 01:59 AM   #14
EatRice
CF Senior Member
EatRice's Avatar
I am sure you have seen a few. You also mention "professionally" done enclosures. There is a big problem with the car audio retail industry and that is any person with a few bucks can open a store and now be a "professional installer." That is a load of crap. Some people will argue that MECP makes you a professional....no that makes the MECP certified installer a person that has time to get on the right track to be a professional but MECP gives no hands on experience. I have worked in the industry for 15 years. I started sweeping shop and doing the crap work when I was 15 years old. I have managed and owned several installation bays and stores. I currently own a successful fabrication business that ventures out of the realm of car audio and into home theater and custom cabinetry. I live in a state where car audio shops are a dime a dozen and they open and close every day. So if you have seen a professional built crap enclosure it is time to find another professional. Sorry I had to get that off my chest since there are o many more so called professionals that drag a true professional 12v installers title through the mud. Happy holidays
Reload this Page Trying to pick a new sub
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Trying to choose a new 12" sub? LPDesRoche Audio/Electronics 16 06-08-2005 11:31 AM
C6 -- You wanted another "professional review" -- Missed Opportunities EHS C6 Corvette General Discussion 49 03-08-2005 06:51 PM
C6 today in the New york Times hibiscus805 C6 Corvette General Discussion 36 03-08-2005 05:17 PM
LMAO - A MUST READ FOR THE DIE HARD C5'ers AC54ME C5 General 61 03-07-2005 08:42 PM
Looking for a DEEPER sound not obnoxious gymrat C5 General 39 08-25-2004 08:59 PM
Launching a Z06 for drag racing oderja C5 Z06 Discussion 14 03-19-2003 11:19 PM
Pacific Northwest Stars & Stripes Tour complete!! Terry Corp Southern California 43 07-03-2002 04:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
