Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-03-2003, 06:38 PM   #1
Cajundude@EnglandGreen
Supporting Tuner
Houston Events Coordinator
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11
Support Corvetteforum!
Cajundude@EnglandGreen's Avatar
Location: ========= Houston, Texas www.englandgreen.com ============== Necessary Evil™ __ 281.464.2800
Default C5 stealthbox questions
I am trying to figure out which box I want to buy from Mike or make myself and was hoping some may give me some insight. Maybe at 32 I am a little old to be worrying about loud music but screw that, I want :banghead: loud. My question is, does the stealthbox give you a lot of good clean bass? Will it rattle your teeth out? Or should I go with the super hang-over box that Mike has and get a good quality sub. I prefer the stealth look but would rather a good clean loud system.
I also saw the post regarding the fiberglass box that Conquer made and how to make it in this forum. That looks really good. If you read this Conquer, how did it come out and sound? Are there advantages to the fiberglass box? It appears that it gives more air space than the mdf boxes. Is that true? Is it stronger?
I'm worried about not being able to buy a good enough quality sub to fit in the stealthbox. Are there any stealboxes in the Houston area? I would love to hear how one sounds. Thanks.
[Modified by Cajundude, 10:42 PM 11/3/2003]
Cajundude@EnglandGreen is online now   Reply With Quote
Old 11-03-2003, 07:15 PM   #2
leolufse
CF Senior Member
leolufse's Avatar
Send a message via AIM to leolufse
Default Re: C5 stealthbox questions (Cajundude)
Wow, lots of questions.
"ratteling your teeth out" also known as Sound Pressure Level (SPL), is more than just a function of the enclosure. The advantage of fiberglass over the MDF stealthbox is interior volume, and strength. Many SPL subs will have bigger magnets, longer mounthing depths, and and require more internal volume to physically mount into a box and achieve the pounding low frequency reproduction you desire. A ported enclosure will give the most pound for your money, but often require an enslosure much too big to fit in the center compartment of a C5. You will need to first determine your budget, musical tastes, and how much room you want to give up for your enclosure. Then you can choose a sub and build a box for its optimal performance. Also don't forget, big SPL subs in sealed boxes will require big power (1000 watts or more) to achieve their full potential. :smash:
[Modified by leolufse, 6:17 PM 11/3/2003]
leolufse is offline   Reply With Quote
Old 11-03-2003, 08:27 PM   #3
Supporting Tuner
Default Re: C5 stealthbox questions (leolufse)
I'm thinking of a 12 W6 with a 500/1 amp pushing it. I thought about the W7s first but that is probably going to be overkill plus they would be too power hungry. I definitely want to feel the bass on occasion and since I have not heard a stealthbox yet I'm kind of leary of buying it. I'd rather have and not need then to need and not have if you know what I mean. Maybe I'll just wait and see if anyone in the Houston area has a stealthbox that I can hear.
Thanks for the info.
Old 11-04-2003, 12:52 AM   #4
EatRice
CF Senior Member
EatRice's Avatar
Send a message via MSN to EatRice
A stealth box will work just fine as long as it is sturdy and to the correct airspace for your sub. Whether an enclosure is hidden or not does not matter as long as it is built well and to the correct specs of the driver.
EatRice is offline   Reply With Quote
Old 11-04-2003, 02:20 AM   #5
mike76002
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08
mike76002's Avatar
Cajundude, if you go with JL 12W6, it may fit in my regular hang-over box which has about 1.2 cu. ft. what 12W6 needs from 0.9 to 1.5 cu. ft.
You just need to find out the magnet diameter by contacting JL.
If you got a coupe or a FRC, this 12W6 will give you more than enough bass.
mike76002 is offline   Reply With Quote
Old 11-07-2003, 11:05 PM   #6
Conquer
CF Senior Member
St. Jude Contributor
Conquer's Avatar
Quote:
...I also saw the post regarding the fiberglass box that Conquer made and how to make it in this forum. That looks really good.
Thanks!
Great! and even better!
Yes... that is true... yes, its is stronger depending on how many layers are used.
:cheers: :cheers:
Conquer is offline   Reply With Quote
Reload this Page C5 stealthbox questions
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
[INSTALL] Who says you can't stuff 2 tens in a stealthbox? Part 1. leolufse Audio/Electronics 11 10-08-2003 11:25 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
