Re: Can this alarm be installed in a '92? (Hammer)
I don't know that answer but I have some advice.
The installation is just as important, if not more important than the alarm itself. IMO, if you have to ask this question, do yourself a favor and find a recommended car audio shop and have them do the install for you and use what they recommend since they will be familiar with that product. It might cost a little more that way but will be worth it in your peace of mind and stress level. Good luck :cheers:
Re: Can this alarm be installed in a '92? (knewblewkorvette)
I'm definately having it professionally installed. I wanted toknow if there was anything electronic that a 92 didn't have keeping me from having this installed.
looking at the web site you provided, the Corvette is not listed as compatible with this alarm 4100 upgrade. The 3000 alarm does list the Corvette but not in years. I suggest you try and call them?
Again, good luck :cheers:
It should work, But you will need to set-up the factory alarm to disarm with the remote. I have the VKE 1000 and it works with my 91 wiring. If I would have known about those others I might have gone that route and disabled my stock alarm..
I have an older Cliffird 8000 alarm I never installed since i heard too many bad things about clifford on this forum
