Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-10-2003, 09:30 PM   #1
Wheelman
CF Senior Member
Wheelman's Avatar
Send a message via AIM to Wheelman Send a message via Yahoo to Wheelman
Default Need help with radar detector hardwire.....
I have had my radar detector hardwired for over a year and its worked fine but recently it has been blowing the fuse or not coming on. I found a short in the hardwire and cut out that section of the wire, replaced the fuse and then checked that the wire was gettting twelve volts when the key was on and it still is. However when the key is turned off i notice that there is still about 35 or so millavolts of power going through that wire. I didn't check to see if this was there before i first installed the radar over a year ago. Is this voltage no big deal or is it a hint on how to solve my problem?? If so what does it represent?? Thanks in advance....
Wheelman is offline   Reply With Quote
Old 09-11-2003, 07:25 PM   #2
C54TIM
CF Senior Member
C54TIM's Avatar
Send a message via AIM to C54TIM Send a message via Yahoo to C54TIM Send a message via Skype™ to C54TIM
Default Re: Need help with radar detector hardwire..... (Wheelman)
What do you have it wired to?
You can disconnect the Radar detector and check the other connections to verify they need 35mv.
If so you might want to try another power source. This will drain your battery in time. When the car is off the Radar detector should be off.
Best of luck to ya,
Tim
C54TIM is offline   Reply With Quote
Old 09-11-2003, 10:13 PM   #3
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
Without more details it's hard to say. Maybe it draws a little to keep the operators settings as you set them so you don't have to do them every time you start the car :confused: Personally, I wouldn't worry about it. 35 milli volts is not going to blow a fuse but the short definetely will.
knewblewkorvette is offline   Reply With Quote
Reload this Page Need help with radar detector hardwire.....
Tags
corvette, detector, hardwire, radar
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
