Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-24-2003, 11:41 PM   #1
Blu Mi C5
CF Senior Member
Blu Mi C5's Avatar
Default Anyone install the new JL 8W7 into the doors of a C5?
If not, would anyone venture a guess as to whether or not they would fit? It's a lot of mass to put in the door, but they would probably sound sweet.
PJ
:cheers:
Blu Mi C5 is offline   Reply With Quote
Old 07-25-2003, 12:38 AM   #2
aurik
CF Senior Member
Cruise-In IV Veteran
Elite Member
aurik's Avatar
Send a message via AIM to aurik Send a message via Yahoo to aurik
Default Re: Anyone install the new JL 8W7 into the doors of a C5? (Blu Mi C5)
There's no way you'd be able to fit one of those in there... I think they need 8" mounting depth. You *might* be able to fit one in each of the side wells though.
aurik is offline   Reply With Quote
Old 07-25-2003, 02:04 AM   #3
Wicked C5
CF Senior Member
St. Jude Donor '04
Support Corvetteforum!
Wicked C5's Avatar
Send a message via AIM to Wicked C5
I have 8 inch Mb quarz subs in the door. The doors are very deep
Wicked C5 is offline   Reply With Quote
Old 07-25-2003, 04:08 AM   #4
Tuan Le
CF Senior Member
Tuan Le's Avatar
I just don't understand why people would want to put a sub in the door. :confused: It wouldn't do it personally.
Tuan Le is offline   Reply With Quote
Old 07-25-2003, 11:25 AM   #5
Conquer
CF Senior Member
St. Jude Contributor
Conquer's Avatar
8W7 in a door :eek: ....:skep: dont think it would fit much less get its full potential out of it. Thats a big 8!
Conquer is offline   Reply With Quote
Old 07-25-2003, 12:35 PM   #6
MHLY01
CF Senior Member
Default Re: Anyone install the new JL 8W7 into the doors of a C5? (Conquer)
Unless you build out the door pods and panel about 6", there is no way that a 8W7 will fit. The pods would hit your knees when you sit down. The doors are very deep but you have to have clearance for the window to roll down. Up front subs are great for sound quality when you want to have proper staging for competition, but for most people it really won't matter. If you really want up front subs, you might try the Illusion 10" inverted magnet subs. Very shallow mounting depth and they could if with some cutting I believe. They do not sound to bad either.
http://www.solen.ca/ill.htm
Just a thought, there are alot of things you could do, even put good ol JL 6W0 mini subs up front in each door or dual Focal 5ws mini subs in each door. They both work well but will not give you the output of a larger sub.
MHLY01 is offline   Reply With Quote
Old 07-25-2003, 02:00 PM   #7
Blu Mi C5
CF Senior Member
Blu Mi C5's Avatar
Sounds like it would not fit from the feedback given. I was thinking that the front of the speaker would be the bottleneck and not the back. The back requires a mounting depth of less then 7 inches, but the front sticks out about 1.5inches (Reading through the lines of the JL literatue)
I am curious as to why some people don't think subs in doors are a good idea. If my memory serves me correctly, Richard Clark's Buick Grand National had a 12" sub in it for mid bass. People asked why he was running such a big speaker, his response (paraphrased) was that while it is not typical for 12" speakers in cars to be used for midbass it is very common for concerts.
Any thoughts?
:cheers:
Old 07-25-2003, 04:29 PM   #8
MHLY01
CF Senior Member
The Grand National built by Speaker Works fist time around had 12" midbass drivers in the rear corner panels. Proper tuning and time alignment made teh car sound unbelievable with the upfront horns the car ran. Then had 15s in the back for sub-bass. You will need a very efficient fast speaker for such a woofer to play midbass. Typical midbass drivers are 6.5" because their response is much faster then a 10" or 12" will be. But a 10 or 12 in a small enclosure it would work well. You could do some fun things in a vette :D
Here is a link to the GN:
http://www.usdaudio.com/sw/cars/buick/page1.html
[Modified by MHLY01, 2:32 PM 7/25/2003]
Old 07-25-2003, 06:48 PM   #9
Kale
CF Senior Member
Kale's Avatar
Default Re: Anyone install the new JL 8W7 into the doors of a C5? (Wicked C5)
Even if you could fit them, assuming they do IB well... there is almost NO way you could dampen the door enough to handle them....
the "response" thing is BS with any quality component... My IDMAX 12 has better response than my CDT 8's... And the CDT8's have excellent response... it all depends on how its built.
I would also assume the 13w7 soudns just as good as the 8w7.. only much much much much much louder.
[Modified by Kale, 2:50 PM 7/25/2003]
Kale is offline   Reply With Quote
Old 07-26-2003, 09:18 AM   #10
M396 #00-011
CF Senior Member
M396 #00-011's Avatar
Do it, I dare you ;)
M396 #00-011 is offline   Reply With Quote
Reload this Page Anyone install the new JL 8W7 into the doors of a C5?
Tags
8w7, 8w7response, door, instal, install, installs, inverted, jl, midbass, tuning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
