Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-26-2003, 12:52 AM   #1
Bruthish
CF Senior Member
St. Jude Donor '03-'04-'06-'08-'09
Bruthish's Avatar
Send a message via AIM to Bruthish
Default What causes this?....
I have a 4x45 head unit(I know it's nowhere near that in reality)...and 6x9's in back and 3.5's in the front. IF the volume gets up there the 6x9's start clipping out at each bass note....is this due to 1) low power 2) thin bose wiring or 3) bad speakers.
I have an 4 channel amp on the way hopefully it will sound beter.....
Bruthish is offline   Reply With Quote
Old 06-26-2003, 01:24 AM   #2
1COOLPC
CF Senior Member
1COOLPC's Avatar
Default Re: What causes this?.... (Bruthish)
I would guess 1 first. Maybe 3 but you would know the answer to this; are they cheap speakers?
Are you sure the woofers aren't hitting anything at full extension? Make sure the foam surround or the cone isn't striking something when it pushes forward.
1COOLPC is offline   Reply With Quote
Old 06-26-2003, 01:30 AM   #3
Bruthish
CF Senior Member
Bruthish's Avatar
Default Re: What causes this?.... (1COOLPC)
They are new pioneers.....I think it's too low power myself...the display on the head unit kinda dims on bass notes....hopefully amp will help
Old 06-26-2003, 01:35 AM   #4
TheWacoKid
CF Senior Member
Cruise-In II Veteran
Cruise-In III Veteran
Send a message via AIM to TheWacoKid
One thing that I noticed help a whole lot was replacing the recievers power wire with 8 gauge. My display no longer dims at high volumes and the sound is much clearer. :cheers:
TheWacoKid is offline   Reply With Quote
Old 06-26-2003, 02:08 AM   #5
Kale
CF Senior Member
Kale's Avatar
Default Re: What causes this?.... (TheWacoKid)
1) turn the bass down
2) run a high pass filter of 70hz to the rear
Kale is offline   Reply With Quote
Old 06-26-2003, 02:49 AM   #6
Bruthish
CF Senior Member
Bruthish's Avatar
Default Re: What causes this?.... (Kale)
I already turned the bass down to -2....I thought about the bass-blockers...but...its not even that loud and there isn't that much bass.....I am not talking rap-bass or heavy bass...just like kick drums in normal rock songs.....
Reload this Page What causes this?....
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What causes this to happen? Shark Racer C3 Tech/Performance 21 02-16-2005 01:23 PM
What Causes This To Happen? nastee383 C3 Tech/Performance 9 07-01-2004 11:13 PM
Service Traction Soon and Reduced Engine Power simulatneoulsy, what causes this? C5Noir C5 Tech 10 11-30-2002 12:10 PM
Deposits on valves? What causes this? They almost looked cracked. bill mcdonald Engine Mods 9 03-22-2002 12:37 PM
What causes this restoration psychosis ? Ron D Factory Correct Resto 22 12-04-2001 12:40 PM
What causes this and what is it called? QWK SLVR C5 Tech 13 08-23-2001 11:35 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
