Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-16-2003, 01:05 AM   #1
pillowmeto
CF Senior Member
pillowmeto's Avatar
Send a message via AIM to pillowmeto
Default after market radio in 76, 2 odd problems
ok i have a 76 corvette w/ an aftermarket radio installed by the previous owner, it is one of those digital but semi orgional looking ones. it has 4 channels so i have rear speakers too, after market. now the first problem is that when i turn the car off i loose all presets, keep in mind i did not wire this. if i turn off the radio and keep the car running that is not a problem. the second problem is that when i turn on the radio it doesnt come on right away. it can take anywhere from 30 seconds to 5 minuties to turn on, but the little lights come on right away, the ones that iluminate the buttons. and this happens everytime i turn on the radio, not just the first time.
any help would be appriceated on this, keep in mind i did not instakll this, nor have i removed it to look at the wireing yet, i wouldnt know what im looking at. I think they might have gotten a live wire, jusyt not the right wire.
MAtt
pillowmeto is offline   Reply With Quote
Old 06-16-2003, 01:19 AM   #2
Metal Wulf
CF Senior Member
Metal Wulf's Avatar
Send a message via AIM to Metal Wulf
Default Re: after market radio in 76, 2 odd problems (pillowmeto)
not sure about problem 2, but I know how to fix problems 1 :D
the HU should have a constant power wire and a switched power wire. Whoever installed it put the constant or both power wires connected to your igniton. The constant power wire is for holding your presets and stuff, the switched power goes to the ignition to turn the unit on and off when you turn the car on and off.
Fix a little bit of the wiring and you'll be set. Also your second problem might be caused by the screwed up wiring job, so you might be able to fix both problems in one shot.
Let us know how you make out :cheers:
Metal Wulf is offline   Reply With Quote
Old 06-16-2003, 03:47 PM   #3
pillowmeto
CF Senior Member
pillowmeto's Avatar
if im not moistaken the orginal radio had no presets that would be saved by a constatnt power wire, they were a button you pressed to move the slider neddle to a certian spot. so if it had no need for one then would it have one. im just thinking i might not have a constatnt power wire to pluginto the back of the radio, and only a ignition wire. so how would i install one in my car, and wetal wuff have you put a radio in your 78, if so how did you do that install, did you need to make a constant power wire for it.
MAtt
Old 06-16-2003, 04:38 PM   #4
Metal Wulf
CF Senior Member
Metal Wulf's Avatar
You'll need to check the back of your HU to see what wires it does have...
When I installed my pioneer I needed to run all the wires, as there was already a single din radio in it, but the wiring was all hacked up.
Making the wires yourself is easy. Just find a constant on 12v souce and tap it. then find a 12v source that switiches with the ignition and tap it. Might want to check the rest of the wires while you're in there as well.
[Modified by Metal Wulf, 4:39 PM 6/16/2003]
Old 06-16-2003, 11:33 PM   #5
pillowmeto
CF Senior Member
pillowmeto's Avatar
thanks wulf, ill pull it apart tomorrow and see what i can find/ do. ill posyt my findings tomorrow if i can.
MAtt
Reload this Page after market radio in 76, 2 odd problems
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
