Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-15-2003, 11:21 PM   #1
Stingraynut
CF Senior Member
Stingraynut's Avatar
Default Where can I fit my amp in 88
I removed my Bose head unit yesterday, I had planned to fit a 4 channel 500 watt amp with the new system but can’t find anywhere to put it.
I would prefer not to lose any room in the car, so I took the dash apart but there’s no where I can fit this amp – it’s 11.5” x 9.5” x 3”
My car is converted to RHDrive so I expect everything behind the dash is less tidy than original, plus the heater is on the LH side (and probably upside down) which fills 90% of the LH space behind the dash. The RH side is jammed full of wiring harness pedals brakes etc.(there’s hardly room for my feet !)
http://www.users.bigpond.com/mpheale.../NakedDash.jpg
Is there room behind the rear wall of the cargo area, maybe on one side ?
Does anyone have any suggestions, if not my alternative appears to be to return the amp and get a smaller one which I think will fit behind the passenger crash pad area and use it just to power the rear 6x9’s.
S’nut
Stingraynut is offline   Reply With Quote
Old 06-16-2003, 02:37 AM   #2
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Default Re: Where can I fit my amp in 88 (Stingraynut)
Have you considered one of the storage compartments in the back? Just make sure the amp is well ventilated.
_Nomad_ is offline   Reply With Quote
Old 06-16-2003, 08:59 PM   #3
Charlutz
CF Senior Member
Default Re: Where can I fit my amp in 88 (_Nomad_)
or under the passenger seat?
Charlutz is offline   Reply With Quote
Old 06-16-2003, 09:17 PM   #4
Stingraynut
CF Senior Member
Default Re: Where can I fit my amp in 88 (Charlutz)
I did try to fit the amp in the LH storage compartment, I think it will squeeze in. I’m not sure how to ventilate it, without letting in road dirt and water. Plus I’d have to run several cables to and from it . So I’m reluctant to do it.
There’s zero room under the seats, they are powered sports seats.
Thanks for your replies. I’m probably asking an unanswerable question but I was just hoping there was a special place I didn’t know about – like the post recently from someone who had just discovered those storage areas after having the car for a while !
My 4x50watt Sony CD player wasn’t too bad in my Fairlane so it should seem louder in the smaller area of the vette. I just wanted that little bit more volume, the bass was sucking up the power. I discovered here that 50watts is only about 20watts RMS. If the 4x50 had been a RMS measurement I’d have power to burn.
S’nut
Old 06-18-2003, 02:41 AM   #5
Stingraynut
CF Senior Member
Looks like I can fit the amp on the floor just ahead of the passenger seat.
Can I put the floor carpet over it ?
How much ventilation does it need ? 4x500watts (not RMS)
S’nut
Old 06-18-2003, 01:11 PM   #6
Charlutz
CF Senior Member
S’nut
Better to build a box and carpet the box matched to your interior. You could also do this in the rear of the car. Keeps the amp hidden, protects it when you put stuff back there (or if in the front, from your pasenger's feet) and the clearance of the box allows for some ventilation.
Reload this Page Where can I fit my amp in 88
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
