Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-16-2003, 03:09 PM   #1
monkeyboylawyer
CF Senior Member
Default BOSE Must Go! Help with choices...
My Bose must go. I am looking for something with better sound. Esp at higher volumes since the vette is a vert.
Can anyone give me some recommendations as to replacement parts (decks, speakers and amps)? I would like a 2xdin to fill the space of the Bose and would prefer not to do any cutting for speakers (ie I want to mount them where the old ones are).
Thanks!
monkeyboylawyer is offline   Reply With Quote
Old 05-17-2003, 01:04 AM   #2
Bodhi
CF Senior Member
Bodhi's Avatar
Default Re: BOSE Must Go! Help with choices... (monkeyboylawyer)
I looked at several double dins but I decided to go with a single din Alpine....Metra makes a great install kit that has a 3 cd pocket that fits below the radio...it looks factory.
Anything you pick will be 10x better than the Blose system.
My Boston Acoustics are mounted in the factory locations and I am using the factory speaker covers. You will need to run new wire to the speakers. I left the factory wire in place in case I ever wanted to put the original crappy system back in :smash:
Bodhi is offline   Reply With Quote
Old 05-17-2003, 01:50 AM   #3
aurik
CF Senior Member
Cruise-In IV Veteran
Elite Member
aurik's Avatar
Send a message via AIM to aurik Send a message via Yahoo to aurik
You're going to be very unlikely to find a *good* double-din system. Your best best will be to go with a single DIN system and a faceplate. Personally I'm very happy with my Alpine CDA-7897, but there are other good systems out there (Alpine and others). I'd recommend going to your local stereo shop and listening to what they've got. Find out what you like and then order it from your online dealer of choice. With a vert you can probably go with a nice 2-way or 3-way set of components up front, no rears (unnecessary if you're running a good set of fronts), amps, and a sub.
aurik is offline   Reply With Quote
Old 05-26-2003, 10:03 PM   #4
Racer_X
Junior Member
Racer_X's Avatar
Default Re: BOSE Must Go! Help with choices... (Bodhi)
Bodhi, which Metra install kit/model# are you referring to? I'm searching their site, but am having a hell of a time locking in on the one you mention. Thanks!
Racer_X is offline   Reply With Quote
Old 05-27-2003, 12:04 AM   #5
mike76002
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08
mike76002's Avatar
Default Re: BOSE Must Go! Help with choices... (Racer_X)
I got a 1.5 DIN Pioneer and I am about to replace it with a single DIN ... I love the look of the 1.5 DIN since it's filling the space but the SQ is not much there and no MP3/WMA but I got a CD changer.
I really wanna go with Alpine CDA-7995 but may settle down with Clarion 835.
If you wanna check out how Pioneer 1.5 DIN in a Vert (yep, I also got a vert), check my webpage ... many pix there :D
:cheers:
mike76002 is offline   Reply With Quote
Old 05-27-2003, 01:16 AM   #6
TigerVette
CF Senior Member
TigerVette's Avatar
I have the Alpine 1.5 din CDA 855D. Fills the opening very nicely. However, I'm not sure if they're still available in retail. I've seen them on eBay. Good luck.
:flag
TigerVette is offline   Reply With Quote
Old 05-27-2003, 07:24 AM   #7
90EXPVette
CF Senior Member
90EXPVette's Avatar
Bodhi,
Give us some specifics on how you replaced your speakers. I replaced the head unit a couple of years ago and now the Blose speakers are going out. What sizes fit front and rear? Did you have to do any cutting/drilling? I need to change my speakers like yesterday!
Joe
[Modified by 90EXPVette, 5:24 AM 5/27/2003]
90EXPVette is offline   Reply With Quote
Old 05-27-2003, 10:26 AM   #8
Fett
CF Senior Member
Fett's Avatar
Default Re: BOSE Must Go! Help with choices... (90EXPVette)
Here's what I did...
First off, I have a 1994 coupe.
I got 4 X 6 speakers up front and 6 X 9's out back. the fronts bolted right in, but I did have to do some minor drilling in the back. I still used the factory speaker covers. You also need to run new wiring for the speakers/
As for the Stereo, I got a JVC double Din unit for the car. It probably is not the best out there, but has 45 watts and sounds infinatly better then the non-Bose unit I had. The biggest benifit IMO is that it fits perfectly into the car. The only problem is it is a silver color, and not black.
With the receiver unit behind the Pax seat, it was a lot more work to install then I planned, but after a day of playing, I have a very nice, clean installation.
Fett is offline   Reply With Quote
Old 05-27-2003, 06:15 PM   #9
jhughes2101
CF Senior Member
Default Re: BOSE Must Go! Help with choices... (Fett)
Why can't you use the current wiring to the Bose speakers that are already in the car. By the way, I pulled mine out my rears yesterday and both circuit boards are toast, doesn't look like an easy repair like I was lead to believe!
jhughes2101 is offline   Reply With Quote
Old 05-28-2003, 12:58 AM   #10
Sinjin90convt
Junior Member
The metra install kit is part #99-3051. Will accomodate a single din and a storage compartment.
Sinjin90convt is offline   Reply With Quote
Old 05-28-2003, 05:44 AM   #11
vrumvrum
CF Senior Member
vrumvrum's Avatar
Default Re: BOSE Must Go! Help with choices... (Sinjin90convt)
looks like I better get on that mounting kit for the late model C4's. :D
http://www.flamingpaperbag.com/radioinstall/
vrumvrum is offline   Reply With Quote
Old 05-28-2003, 10:30 AM   #12
Bodhi
CF Senior Member
Bodhi's Avatar
Default Re: BOSE Must Go! Help with choices... (jhughes2101)
From what I have been told the Bose wiring is 1 ohm and aftermarket speakers need at least 4 ohm.
Old 05-28-2003, 02:42 PM   #13
Fett
CF Senior Member
Fett's Avatar
:iagree:
That's the problem!
Old 05-28-2003, 03:51 PM   #14
jhughes2101
CF Senior Member
I guess my ignorance is showing, but the four wire connector to each speaker looks like ordinary copper wiring. Is the diameter too small to run enough current to power the speakers?
Old 05-28-2003, 07:10 PM   #15
corvette-pilot
CF Senior Member
corvette-pilot's Avatar
It would be my guess that 2 wires are for power (+12v, GND) and the other 2 are the signal into the speaker amps.
The gage isn't the issue.
I have also heard it is something to do with impedance matching. Best bet is to replace everything at once.
corvette-pilot is offline   Reply With Quote
Old 05-31-2003, 06:44 AM   #16
mitymek
CF Senior Member
Send a message via ICQ to mitymek
Default Re: BOSE Must Go! Help with choices... (corvette-pilot)
hmmm,i too hate to run wires mainly because its more clutter.theres a post in general (i think) where someone used the oem speaker wires with no prob.
how bout it delco/bose experts-is the 2 speaker signal wires to the bose speakers some kinda resistance wire?
im certainly no electronics expert but this is the first reference ive heard of 1 ohm carrier wire.
im wondering if the low wattage signal to the bose amps isnt confusing the issue maybe?
what gage wire is the oem bose speaker wires?
why not tie the 4 wires into sets of 2 and use em maybe? :confused:
mitymek is offline   Reply With Quote
Old 05-31-2003, 06:55 AM   #17
mitymek
CF Senior Member
Default Re: BOSE Must Go! Help with choices... (mitymek)
oh yea,an answer to your main query.
ive been looking for a few hrs at different options for late c4 stereo parts.one of my main concerns is factory look.
never could find out what exactly "din" is but c4s to 89 use din 1.5.
havent tracked down for sure if my 92 is too but i think 90-96 could be closer to din 2 size opening.
there only a few options with the din 1.5,the best being the pioneer (surprisingly much better than the alpine 1.5 offering)
and even that best pioneer offering isnt worthy of the vehicle imho.
plus it just doesnt match worth beans.
im thinking along the lines of sandwiching a din 1 cd receiver on top of an equalizer that will equal the opening.
if someone could post the exact opening specs that would be cool ;)
if the cd/equalizer stack would work then youd have a bazillion options for looks performance on both units.
Old 05-31-2003, 04:52 PM   #18
baldie
CF Senior Member
St. Jude Contributor
baldie's Avatar
Send a message via ICQ to baldie
Check my signature. This is all you should need. It Rocks!
baldie is offline   Reply With Quote
Reload this Page BOSE Must Go! Help with choices...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ken's Weekly News-12/5/03-C6 News, GMPP Sale, Corvette Sale, Parts Sale! Ken Fichtner Ken's Newsletters 15 01-03-2004 01:13 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
