Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-16-2003, 03:06 AM   #1
tmarshall60
Junior Member
Default aftermarket stereo and SYS warning
I have read and saved a past topic on installing 2 resistors to trick the car into thinking it still has the bose system installed and avoid the sys warning. Does anyone know if this applies to a 93, and what would happen if I fused the stereo direct to the battery and didn't use the power to the old bose? :cheers:
tmarshall60 is offline   Reply With Quote
Old 05-16-2003, 10:59 AM   #2
Marcho Polo
CF Senior Member
Outlaw Moderator
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Marcho Polo's Avatar
Default Re: aftermarket stereo and SYS warning (tmarshall60)
The SYS problem is related to the dimming circuit so I would think that as long as you patch that up you can power your aftermarket unit any way you want and still be rid of the SYS problem.
Just for those that might have missed it, I posted this fix on the forum back in 1999:
If "SYS" is displayed in the LCD section of the instrument panel cluster after the customer installs a new stereo, he will need to do the following:
1. Buy (2) 1 kilo-ohm 1/2 Watt resistors. [Radio Shack part # 271-023. They sell them as a 2-pack for 29 cents.]
2. Disconnect the negative battery cable.
3. Remove the receiver.
4. Connect one end of both resistors to ignition power. (Yellow wire in the car.)
5. Connect the other end of one resistor to the purple/white wire in the car.
6. Connect the other end of the second resistor to the grey/black wire in the car.
7. Cover all connections and completely cover the resistors.
8. Reconnect the negative battery cable.
Marcho Polo is offline   Reply With Quote
Old 05-16-2003, 11:35 AM   #3
Bodhi
CF Senior Member
Bodhi's Avatar
Default Re: aftermarket stereo and SYS warning (Marcho Polo)
I just had a new stereo installed about 6 weeks ago. Driving home I had the flashing SYS light the entire way home. I went to Radio Shack and bought the resistors (that part number has been out of use for 10 years it is now 271-1118)....
The next day I was headed back up to the stereo installer to have them do the resistor fix when I noticed I had no Sys light flashing at all.
So I decided to hold off on the "fix" and see if the flashing SYS light ever came back....6 weeks and it has not come back.
The same thing happened to another guy on here.....flashing SYS light after stereo install and then it disappeared....
There was a TSB from GM about this issue:
http://www.corvetteforum.net/c4/dave8476/index4.shtml
The resistors certainly won't hurt anything so if you are worried go ahead and put them in when you do the install.
Bodhi is offline   Reply With Quote
Old 05-17-2003, 10:26 AM   #4
tmarshall60
Junior Member
Thanks for the advice. I think I will put them in to save another dismantle. Stereo booked in Mon morning after 12 months of deliberation! :)
Old 05-17-2003, 11:57 AM   #5
PurpleC4
CF Senior Member
Cruise-In I Veteran
Currently Corvette-less
PurpleC4's Avatar
Send a message via AIM to PurpleC4
Now moving to the audio section. ~ Purp
PurpleC4 is offline   Reply With Quote
Reload this Page aftermarket stereo and SYS warning
Tags
12, 1994, 1999, 99, aftermarket, corvette, mon, problem, radio, resistor, resistors, service, sys, tire, warning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
SYS and battery GlockLT4 C4 Tech/Performance 10 08-14-2001 10:25 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
