Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-16-2003, 12:52 AM   #1
Ben01C5
CF Senior Member
Default Help fast...Last thing is grounding amp
I have everything wired, and need to find a ground near the back of the car. I mounted the amp on the back wall of the trunk, and am looking for a ground within 2-3 feet.
Ben01C5 is offline   Reply With Quote
Old 05-16-2003, 06:06 PM   #2
C5B
CF Senior Member
C5B's Avatar
Default Re: Help fast...Last thing is grounding amp (Ben01C5)
Well, I never found a good ground that close, but it could exist. I ended up running a 4ga cable to a seat stud.
- C5B
C5B is offline   Reply With Quote
Old 05-18-2003, 08:40 PM   #3
ericdwong
CF Senior Member
ericdwong's Avatar
Default Re: Help fast...Last thing is grounding amp (C5B)
I used one of the muffler bolt clamps for the ground, but I'm probbly gonna redo the setup to using one of the seat bolt posts.
ericdwong is offline   Reply With Quote
Old 05-19-2003, 01:46 PM   #4
Ben01C5
CF Senior Member
Default Re: Help fast...Last thing is grounding amp (eRiCdWoNg)
I am thinking about a seatbelt bolt, or run the wire down to the seat bolt.
I am finishing the whole job up tonight "hopefully"
Old 05-19-2003, 01:55 PM   #5
catfish
Junior Member
catfish's Avatar
Send a message via AIM to catfish
Check out removing the righthand taillight...you may find a braided antennae grounding wire that you can use.
catfish is offline   Reply With Quote
Reload this Page Help fast...Last thing is grounding amp
Tags
2003, amplifier, corvette, grounding, location, trunk
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Audio FAQ bogus Audio/Electronics 49 01-31-2012 04:41 PM
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
