Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-10-2003, 12:43 AM   #1
corvettemaster
CF Senior Member
corvettemaster's Avatar
Send a message via AIM to corvettemaster
Default how to get rid of engine noise
my ground wire is only 6" long. my rca cables and power cables run in opposite directions. for some reason i still have engine whine when reving the car up, turning heat on, shifting gears, etc. i have the system installed in an 81 vette and just have the gound running from the rear compartment to one of the seat bolts. i checked and it's a 12v ground. should i try running the gound and soldering it directly to the frame? or should i get some better insulated rca cables? what else can i do...i'm new to this audio stuff
corvettemaster is offline   Reply With Quote
Old 04-10-2003, 12:54 AM   #2
Tolofou
CF Senior Member
Default Re: how to get rid of engine noise (corvettemaster)
I think you did what we all do and hook up to factory wires and you used the ground off the old harness.. I know mine made a wicked sound with the amps on and it was like I knew it was installed correct. But anyway I tore the whole thing apart and checked my wires. They looked all clean and installed. So I thought if I add an extra peice of wire to the groun wire and put the wire to a solid ground.Well whats solid in these cars. Most Fiberglass Ive ever seen.. The shift lever metal has a nut you can take off and put the wire with a loop conector and it will sound great.. Mine did and 0 noise now.. :)
Rob
Tolofou is offline   Reply With Quote
Old 04-10-2003, 01:00 AM   #3
Tolofou
CF Senior Member
Default Re: how to get rid of engine noise (Tolofou)
Wait a second.. You run your ground to your seat nut?And its only 6 inches long?Good RCA's are very important.. Fosgate has good ones..Monster Cable is another..
Rob
Old 04-10-2003, 01:34 AM   #4
corvettemaster
CF Senior Member
yeah i put the amp in the back compartment area behind the passenger seat. then ran the gound wire through a gourment in the fiberglass that runs through the console area, but i just unbolted the seat, and ran the ground down to the nearest seat bolt, and bolted it back down. it's a solid 12v ground. the only one i could find anyways beside directly on the frame.
Old 04-11-2003, 05:56 PM   #5
86VETTEMAN
CF Senior Member
86VETTEMAN's Avatar
Send a message via AIM to 86VETTEMAN
Did you install a head unit? If you did, when you connected the wires, did anything spark? If so, your head unit could be bad and you might need to replace it. I did this when I first started installing systems. My wife wasn't too happy about it either, but it was on warrenty.
86VETTEMAN is offline   Reply With Quote
Old 04-14-2003, 10:52 AM   #6
joeveto
CF Senior Member
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
joeveto's Avatar
Corvettemaster, I don't have a clue how to battle the noise. I've been fighting this for two years. I'm at the point now, that I'd like to just put a freaking boom box in the back. Just like high school, all over again.
I've done the ground thing, I've kept the power and signal wires separate. I switched to high quality gold RCA's. You name it.
The only thing I can think of, is the antenna. Make sure it's clean and the ground is good.
Also, I've been told hooking up directly to the battery can really help, as it's a natural filter.
And noise filters are worthless.
joeveto is offline   Reply With Quote
Old 04-14-2003, 09:46 PM   #7
corvettemaster
CF Senior Member
Default Re: how to get rid of engine noise (joeveto)
thanks joe. i guess i will try upgrading my rca cables...then try hooking the ground directly to the battery and see if that helps. where do you have your ground wire hooked up at?
Old 04-14-2003, 09:56 PM   #8
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
You have a shark body and the batteries are in the back conveniently next to your amp. Run ground to your battery and you will see marked improvement since the run will still be short. Also, try grounding the HU directly to the frame. Sounds like you did everything else right.
_Nomad_ is offline   Reply With Quote
Reload this Page how to get rid of engine noise
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
.....Just D O I T N O W !!!! Mr Snappy! C5 General 17 03-06-2005 01:14 PM
How to tranlate used car listings YellowYbody C4 General Discussion 13 01-28-2004 10:47 AM
I can't get rid of this engine noise - any ideas? Langadorf Engine Mods 15 01-02-2003 06:08 PM
I have alternator noise, how do I get ride of it? SLICKMAN C3 Tech/Performance 16 10-24-2002 09:02 AM
How do I get rid of "Radio Noise" madmaxgt C3 Tech/Performance 21 05-02-2002 11:12 PM
Pros and cons of the Power effects system brywest C4 General Discussion 12 09-09-2001 03:38 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
