Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-09-2003, 11:02 AM   #1
01 Vert
CF Senior Member
01 Vert's Avatar
Default Can componets be added to 01 C-5 Alarm?
I have any 01 Vert and was wondering if anyone knows if I can add a proximity sensor to the system? I thought this would be good way to go since it is a vert. If one can't be added does anyone have a recomendation on good aftermarket system? I don't want to lose any of the factory features but want some extra protections. Thanks in advance.
Rich :seeya
01 Vert is offline   Reply With Quote
Old 04-09-2003, 12:24 PM   #2
leolufse
CF Senior Member
leolufse's Avatar
Send a message via AIM to leolufse
Default Re: Can componets be added to 01 C-5 Alarm? (01 Vert)
It can be done pretty easily. I added a shock sensor to mine by tapping into the factory harness pin switch that activates the alarm when the hood is opened. You can add a proximity sensor the same way. Do a search in the archives and you should be able to find the link.
You will need to install a switch to kill the power to the sensor when the ignition is on, or else you will get a message on the DIC that says "Tanneau Open". I wanted to install an electronic switch that would do this automatically, but couldn't find one, so right now the sensor is not hooked up to power at all.
I also added a LED in the center consol that comes on anytime the key is out of the ignition. I got it on eBay, it is called "simularm". I think it was like $5.
:cheers:
[Modified by leolufse, 11:26 AM 4/9/2003]
leolufse is offline   Reply With Quote
Old 04-09-2003, 01:15 PM   #3
MVP
CF Senior Member
MVP's Avatar
Try this under the tech tips http://corvetteforum.com/techtips/vi...=207&TopicID=1
[Modified by MVP, 12:15 PM 4/9/2003]
MVP is offline   Reply With Quote
Old 04-09-2003, 01:25 PM   #4
01 Vert
CF Senior Member
01 Vert's Avatar
Default Re: Can componets be added to 01 C-5 Alarm? (MVP)
Thanks for the replys. I even tried calling the dealer.. What a waste that was. "Uuuuhhh we don't work on alarms here" Can you tell who you send them to? "If it didn't come from Gm wit one you is out o luck" And this was from the service writter. Now I remeber why I hate the dealer. Thanks again for your help. I'm going to try some of the local stereo shops and see what they can tell me. I'll post what I find out.
Old 04-09-2003, 01:46 PM   #5
brianw21
CF Senior Member
brianw21's Avatar
Just use a relay connected to the 12v accessory line to deactivate the alarm add-ons while the ignition is on. Any stereo shop will be able to do this for very cheap... maybe $40 in labor.
-Brian W
brianw21 is offline   Reply With Quote
Reload this Page Can componets be added to 01 C-5 Alarm?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
