Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-09-2003, 01:23 AM   #1
Chris Fowler
CF Senior Member
Cruise-In IV Veteran
St. Jude Donor '03-'10
Chris Fowler's Avatar
Default Installing a head unit in a '94. How do I get the console apart?
What do I need to do to take the console apart enough to install a new head unit?
I checked the Tech Tips section. Didn't see anything there. :(
Chris Fowler is offline   Reply With Quote
Old 04-10-2003, 12:02 AM   #2
XTRME 94
CF Senior Member
XTRME 94's Avatar
Send a message via AIM to XTRME 94 Send a message via MSN to XTRME 94 Send a message via Yahoo to XTRME 94
Default Re: Installing a head unit in a '94. How do I get the console apart? (Chris Fowler)
Okay, this is completely from memory so don't shoot the messenger. :jester
First remove the console door. 4 torx screws. You can flip it around and lay it in the back making sure it lays down (light out) or you can pull (carefully) the wiring out from the console area and unplug it. I usually do the prior.
Next, there are 2 small bolts under the front corners of the carpeting on the inside of the console. You'll need to remove those. There's one screw or bolt (not sure as it's missing in mine) underneath the front cup holder cover. Once you're done with that, you should be able to carefully lift the shifter bezel up from the back pulling it away from the radio bezel at the same time as it's hooked there. (you'll see once you get it off) At this point you'll need to disconnect the wires to the hatch button and chose how you want to remove the shift boot from the shifter. Some people will take the shift knob off and slide it over, but in a '94's case if you still have the stock shifter that requires removing the reverse lockout as well. What I do is get a really short screwdriver and undo the boot from the bottom of the bezel (edit - 4 screws - 1 at each corner). Next you'll need a torx screwdriver to remove the A/C vent above the radio. Once that's out, you'll notice 1 bolt attaching the radio bezel behind that to the left. Remove that as well. There are 2 bolts in the bottom of the bezel near where the "tabs" stick out that go in the shifter bezel. Once you have those 3 bolts out, you can carefully pull the radio bezel off. There is a pressure clip to the left of the A/C controller so when you pull it off it helps to have one hand next to that and one on the other side. Pull straight and it'll pop loose. From there, there should be 4 bolts holding the radio in place. Should be obvious at that point. If you need anything else, just ask as I've been in there many times. I hope my (old :lol: ) memory remembered everything.
[Modified by R94 LT 1, 10:05 PM 4/9/2003]
XTRME 94 is online now   Reply With Quote
Old 04-10-2003, 12:43 AM   #3
Tolofou
CF Senior Member
Default Re: Installing a head unit in a '94. How do I get the console apart? (R94 LT 1)
Sounds good to me. But to get the new radio and install kit in you will most likly have to cut a area out behind the deck to make room for the deck to fit..I put my deck in deep..
Rob
Tolofou is offline   Reply With Quote
Old 04-10-2003, 12:56 AM   #4
XTRME 94
CF Senior Member
XTRME 94's Avatar
Default Re: Installing a head unit in a '94. How do I get the console apart? (Tolofou)
Rob
Mine actually fit without cutting in back. I just notched the bezel a bit in the lower corners so it slide over the new face a bit easier. The stock face sits flat against the back.
[Modified by R94 LT 1, 10:56 PM 4/9/2003]
Old 04-10-2003, 11:37 AM   #5
Chris Fowler
CF Senior Member
sounds straightforward enough. Hope it's as straightforward as it sounds. :crazy: :yesnod:
As for depth, I'm hoping it's deep enough already. It's already got an aftermarket stereo in there.
Old 04-10-2003, 12:38 PM   #6
White 68
CF Senior Member
White 68's Avatar
Sent you an IM, but heres a good link.. http://carstereohelp.com/strcorvette.htm :cheers:
White 68 is offline   Reply With Quote
Reload this Page Installing a head unit in a '94. How do I get the console apart?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
94 coupe install tips jsquared94 Audio/Electronics 10 11-07-2002 12:17 PM
How do you remove the harmonic balancer? (LT1/LT4) ZBRA C4 Tech/Performance 14 12-08-2001 12:44 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
