Running Ground From 2 Amps Back to Battery
I want to run ground from 2 of my amps back to battery. Can I run one 4 Gauge wire from battery terminal to a Distribution Block near amps in rear and split ground into 2 4 Gauge different wires that will connect to amps?
Re: Running Ground From 2 Amps Back to Battery (Kale)
Ground wire really should not exceed 18" total.
I see too many people are having trouble when the connect ground to seat. Ripping carpet up a second time to run wires to battery could be big PITA. Should I at least attempt seat connection?
Re: Running Ground From 2 Amps Back to Battery (knesbitt)
I refuse to drill holes in car. I have read that as long as gauge is same a positive I should be allright. Who has had problems with grouinding to battery?
Grounds should be short, and you should never run a common ground between two amps. Doing so will create cross-talk. You want to get the ground to the frame as quickly as possible so you don't get voltage loss in the ground line. The frame has much lower resistance than any type of wire you can fit in your car. It's by far the best way to return current to the battery.
Re: Running Ground From 2 Amps Back to Battery (GTLocke13)
Here is the real reason...
Although everyone has probably forgot at some time, electrons flow from negative (ground) to positive.
The reason for keeping your ground short is:
1. That it's the main supply of power for your system.
2. Ground potential differences induce noise.
Distribution blocks have become popular because they minimize ground differences. In fact that is the single largest problem with car audio.
A. Headunit is grounded usually on the firewall or somewhere VERY near the negative path of the battery. This means that the resistance between that ground point and the battery is almost 0.
B. By running ground wire from the battery you will create a resistance with that wire. This means that the resistance of the head unit ground and amplifiers grounds are different.
C. A resistive difference in a electric circuit causes a voltage drop. This difference is voltage and ground path resistance causes an "Anteanna" effect. Thereby letting noise into the system. This is often reffered to as Ground Loop.
Solution: Minimize the difference in ground potentials of all audio components.
This is relativley easy by using a distribution block and a common ground for all components in a close proximity... but the headunit isn't on that block. We don't want to run a wire from that block to the headunit, because that length of wire and it's size would cause a measurable resistance.... So we ground the amps to the frame, which is the largest conductor possible. This makes the relative ground resistance at the amp VERY close to the one at the head unit.
This applies to systems that have common ground connections between the head unit and amplifiers. So unless you are using optical fiber (no electricity) it applies**.
** Even with a fiber connection AI-net for example makes use of a common ground in the signal chain.
I hope this makes sense..
Short Take: You are usign the frame as a massive conductor to minimize ground potential differences.
Re: Running Ground From 2 Amps Back to Battery (Metal_Wulf)
Well, I have decided to swim upstream on this one. I have my amps grounded at the battery and have absolutely ZERO noise induced into my system. I have grounded right by the amps on every system that I have built and my current install is my first one that is COMPLETELY noise free. Now expain that. :crazy:
Re: Running Ground From 2 Amps Back to Battery (mrkln)
[Modified by knesbitt, 12:48 AM 3/11/2003]
Re: Running Ground From 2 Amps Back to Battery (brianw21)
Any place that there's a reference voltage in a circuit, you have a chance for noise coupling through common impedances. This applies to both power and ground references. The reason you don't get cross-talk on the power line as well is that the DC-DC converter inside the amp (or head unit) has some massive filter capacitors that filter out pretty much all AC signals.
The rest of the post is dead-on though.
While I tend to agree with most of the rational on this thread, I'll be the odd ball. I ALWAYS run a direct positive and negative lead directly from the battery to the amps and processors. WHY? Because all the rest of the car electronics are dumping to ground somewhere and ULTIMATELY end up to the negative BATTERY post. With all that electrical noise within the ground loop itself from other parts of the cars electronics it can pick up ground bounce and signal refraction from the noisy microcessors digital grounds. The ONLY detriment is possibly a .1 (maximum) of a voltage drop from the battery to rear of car, assuming that 4 guage or lower is used to make the connection. I teach electronics for a living and install $100k systems, trust me, if you can swing the cost this is the best way to do it. It guarantees noise can't creep into the system ASSUMING all components do not touch metal of any kind including the antenna to create a ground loop. No ones opinion will sway me from this position so keep your flames to yourself. This is the advantages to having a PhD in electronics..... :yesnod: Don't believe me go to my website and see for yourself under the pictures "current kitt pictures"
Kitt
Kitt
That idea of a filter capacitor on the ground of the amp is pretty good too, I think. I may try that on my system sometime.
