Specialty Autosound Manuf. Install kit for 90-96 double din
I posted this elsewhere here... but wanted everyone to see the kit.
it looks nice.
the actual mounting plate is made of metal...real live METAL.
Re: Specialty Autosound Manuf. Install kit for 90-96 double din (bogus)
It's about time. I was installing car audio for 10 years, and I always hated the cheap plastic Kits for GM's.
Good Find :cheers:
Good Find :cheers:
Where did you get it from..........would be interested in grabbing one......I like my support system for mine but a prefab is usually way better.....
kitt
kitt
Re: Specialty Autosound Manuf. Install kit for 90-96 double din (92TripleBlack)
Looks nice. Can you post a pic of it installed?
sure will.
it looks nice.
Re: Specialty Autosound Manuf. Install kit for 90-96 double din (Nevermind)
Me..tal.. I'm unfamiliar with this material. :confused: :D
and is heavier than plastic.
I will check back and let you know how this "metal" stuff works out. could be a new invention that we should all look into.
:jester
WHERE DID YOU GET THAT AND HOW MUCH DID IT COST?!....I need one for my install next month!
Let's see some pics.
Re: Specialty Autosound Manuf. Install kit for 90-96 double din (SLO19vette91)
It is in, but I need to work on the install some more. I will give details soon!!!
And pics.
the 7998 fits PERFECT... however, the kit needs some massaging... suprise.
it is a nice kit, tho... beats making one!!!
oh, it sounds nice, too. :D
And pics.
Cruise-In IV Veteran
St. Jude Donor '03-'10
Did you mount it at the top, middle or bottom of the opening?
When it extends, how far out does it come?
I remember you mentioned to me that you had a different shifter, so you don't have to worry about it hitting that...
thanks! :cheers:
Re: Specialty Autosound Manuf. Install kit for 90-96 double din (Chris Fowler '80)
I will take pics tonite!!! I have room, but, with a stock shifter, you may run into issues during turn on/off... just don't be in 1-3-5 when that happens.
Pics are in!!!!
The first pic is the head open at its farthest extent. as you can see, the shifter is in 1st and there is still about 3/4". I suspect you have a problem with the stock shifter... but that is why 2-4-6 and neutral :)
The second pic I took with a bit of creative flash blocking... :D
It fits the dash very nicely, I think... and the kit is very nice, too.
[Modified by bogus, 10:48 PM 1/16/2003]
the 7998 has dual illumination? :eek: :confused:
I thought it was green only, but that second pic looks amber :confused:
Here is another of the same kit.. I have since changed the way I installed mine, but have no updated pictures yet
Re: Specialty Autosound Manuf. Install kit for 90-96 double din (-=Jeff=-)
dual illumination!
Is it just the picture or is the stereo not straight? :confused:
I don't have a Picture yet, but it looks much better to me.
Re: Specialty Autosound Manuf. Install kit for 90-96 double din (WILDONETHIRTYSEVEN)
Where did you guys get this kit, i have been searching for a while and havn't found anything. Link please.
Thanks,
Dave
Thanks,
Dave
