Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-24-2002, 04:07 PM   #1
shotchkiss
CF Senior Member
shotchkiss's Avatar
Default Power handling of speakers wired in parallel.
If I have 2 speakers at 8ohms that are rated at 75w power handing, when I hook them up in parallel to create a 4 ohm load does that mean the power handing capacity doubles to 150w then or is it increased to 300w for the pair? Thanks for any help with this.
shotchkiss is offline   Reply With Quote
Old 12-24-2002, 04:13 PM   #2
Kale
CF Senior Member
Kale's Avatar
Default Re: Power handling of speakers wired in parallel. (shotchkiss)
Each speaker can handle 75watts regardless of how they are wired. So if you had two wired to the same "outlet" on the amp, you'd supply 150watts to the pair.
the impedence has to do more with how your amplifier is going to react..
[Modified by Nevermind, 12:14 PM 12/24/2002]
Kale is offline   Reply With Quote
Old 12-29-2002, 03:53 PM   #3
NYN8IVE
CF Senior Member
NYN8IVE's Avatar
Speaker power handling does not change under any wiring scheme. What changes is the output of the amplifier that is connected. Typically, less impedance will increase power output but be careful because some amplifiers will not be very stable at a reduced impedance.
NYN8IVE is offline   Reply With Quote
Reload this Page Power handling of speakers wired in parallel.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
