12-22-2002, 08:48 PM
CF Senior Member
Cruise-In II Veteran
Cruise-In III Veteran
Re: Should I use polyfill? (Son93SL2)
Basically, the closer you get to 1.5 cu ft the deeper the subs will play, at the expense of some spl. If you have more than enough power, I would add some polyfill to deepen the sound. Likewise, the closer you get to 1 cu ft the louder it will get, at the expense of low bass extension.
I would add polyfill, because you can always turn the amp up a little more to compensate--and you get a smoother overall sound. :cheers:
