Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-22-2002, 12:03 PM   #1
Son93SL2
CF Senior Member
Son93SL2's Avatar
Default Sub commong tomorrow
I'm way way too excitied. I have been without my sub for 3 weeks now. :cry
Do I really have to break in the sub?
Son93SL2 is offline   Reply With Quote
Old 12-22-2002, 12:09 PM   #2
TheWacoKid
CF Senior Member
Cruise-In II Veteran
Cruise-In III Veteran
Send a message via AIM to TheWacoKid
Default Re: Sub commong tomorrow (Son93SL2)
You should play it low to moderate volumes for the first 15-20 hours or so to break in the suspension. You will notice a huge difference once it loosens up. You could play it loud at first, but it will sound kinda bad. It is just better to break them in like a car engine. Gentle for a little while, then pound them. :cheers:
Congrats on the sub. What kind did you get?
TheWacoKid is offline   Reply With Quote
Old 12-22-2002, 12:25 PM   #3
Son93SL2
CF Senior Member
Son93SL2's Avatar
Default Re: Sub commong tomorrow (TheWacoKid)
Ok, i'll break her in in one day then. :)
I got this little bad boy.
12w3v2-d2
Old 12-22-2002, 12:40 PM   #4
DC5
CF Senior Member
DC5's Avatar
sweet! My 12w3v2-d4 is scheduled for delivery tomorrow also. I'll be driving it with a 500/1. Can't wait. What kind of enclosure do you have?
DC5 is offline   Reply With Quote
Old 12-22-2002, 02:20 PM   #5
Son93SL2
CF Senior Member
Son93SL2's Avatar
Default Re: Sub commong tomorrow (DC5)
What Ohms are you planning on running your sub at and how many ohms is that 500 watts at?
I have a 1.25 ft^3 with a sloped front. I just finished sealing the interior of the box so now the enclosure is a bit tighter.
I am going to push 375 watts at 4 ohms to my sub wired at 4 ohms. :)
Old 12-23-2002, 11:35 AM   #6
leolufse
CF Senior Member
leolufse's Avatar
Send a message via AIM to leolufse
I just picked up 2 JL 10W3v2-D2s. I put each of them in their own sealed enclosure at .65ft^3. I wired the voice coils in series to give each sub a 4 ohm impedance. I'm running them from a MTX 6500D mono sub amp at about 800 watts at 2 ohms. So each of the subs is getting about 400watts. I'm still breaking in the subs right now, but will all that juice, they don't need to move very much to pound. :smash:
leolufse is offline   Reply With Quote
Old 12-23-2002, 11:45 AM   #7
DC5
CF Senior Member
DC5's Avatar
I'm planning on wiring the single 12w3v2 D4 in parallel for a 2ohm load for the JLAudio 500/1. This will be my first JLAudio amp (I've also got a 300/2 ordered for the front speakers) and it has some type of variable regulator for the ohms in addition to the voltage. My understanding is that from 1.5-4 ohms, this amp will deliver 500w. I haven't yet started to build my cabinet. I had better get busy. :cheers:
Old 12-23-2002, 12:20 PM   #8
leolufse
CF Senior Member
leolufse's Avatar
Yes you are correct about the 500/1 amp. 500watts at 1.5-4 ohms. So if you ever wanted to add another 12w3v2 D4, just wire both subs in series for an 8 ohm impedance per sub. By hooking up two 8 ohm subs to a mono amp, it will "see" a 4 omh load. That will be 250 watts for each sub, not too shabby.
[Modified by leolufse, 11:22 AM 12/23/2002]
Old 12-23-2002, 02:03 PM   #9
DC5
CF Senior Member
DC5's Avatar
Default Re: Sub commong tomorrow (leolufse)
:thumbs:
Old 12-23-2002, 03:20 PM   #10
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Yeah, in essence they are wired series/parallel since they're hooked to a mono amp. Just in case anyone is interested.....if you don't have a mono sub amp and if your amp handles 2-Ohm MONO not stereo, you could just wire the subs series/parallel yourself by wiring the 2-Ohm DVC's in series to 4-Ohm and then the two subs together in parallel (bridged) to the amp leaving a 2-Ohm mono load on the amp. If you had 4-Ohm DVC's you could wire them in series to 8-Ohm then the subs together in parallel to the amp for a 4-Ohm mono load. This last Ohm configuration is better for amps not designed for a 2-Ohm mono load, which most non-mono amps aren't.
Just a little FYI for any who want to know. :seeya
_Nomad_ is offline   Reply With Quote
Reload this Page Sub commong tomorrow
Tags
12w3v2d4, 4omh, 500, 5001, amp, jl, single, watt, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
