12-21-2002, 02:01 AM
CF Senior Member
Re: Ragtop Upgrade Recommendations (FYNL4)
Most bang for the buck would be to get a 10 or 12" sub and a decent amp for it. You can get both for under $500. I would recommend a 12" for a vert. due to the fact that the top is down most of the time and it blocks the path to the trunk area. This is a good starting point and should make the stock system come alive!
I am installing a Diamond Audio MacDaddy 12" sub in a custom stealthbox for the center compartment and a JBL 1200.1 (1200 watt) sub amp. I think it should have a little THUMP:eek: in it!
[Modified by MTWallet, 6:33 PM 12/22/2002]
