Quote:
has anyone compared dynamat with raamat or Be quite-as far as effectiveness.
Yes, I have. In fact, I have Be-Quiet Brown-Bread in my Vette's now. The C4 took about 130 ft^. I did 3 to 5 layers on the doors, rear hatch area, floor pan and up the firewall, every nook and crany. It really helped a lot. The Brown-Bread is the exact same thing as the Dynamat Extreme but cost a lot less. Raamat is good to but is thinner and will require more layers but it cost even less than the Brown-Bread does. I paid around $100 USD for a 100 ft. roll of Brown-Bread on ebay. It's all over the place there for cheap, check it out. Just don't spend a lot on Dynamat when it isn't any better.
Quote:
And one more question....will any of the above stick real well against the vertical surface inside the door- the outer wall of the door?
Thanks for all help!
Yes, it will stick just fine. I used a heat gun and roller (
wooden wallpaper roller) to apply it. I would hate to have to try and remove it, it's on for good! :thumbs: :steering:
