Question About Space Behind C6 Radio
I have been doing a lot of research and reading about installing an aftermarket radio in my C6. It's a lot different than when I've installed radios in the past!
I have the Bose navigation system now. I only plan on replacing the radio. Maybe one day I will do the speakers, but not right now. I do realize that new speakers, amps etc will make a huge difference. It's just not something I want to do right now.
Anyway, I've read that in order to keep my steering wheel controls, the chime and other things, I need to use the RP5-GM11. I have also read that a lot of people experience engine noise if they only do the radio and not speakers, so people suggest using two ground loop isolators. I also plan on running the USB cables to my center console and replace the 12v plug with a dual USB outlet.
The radio I'm looking at has a cd/DVD player on it and is standard depth. My question is, will all of this stuff fit behind the radio? Like I said, I've done some car stereo installations in the past, sometimes there is room back there and other times there isn't. Will I have any issues with space or will I be ok?
joec (05-07-2021)
unkled20 (04-27-2021)
Yes there's room for a double DIN, you just need to make sure to pull the wiring and interface below it (there's plenty of room to do so), if you try to stuff the all the wring and interface behind the radio, it won't fit. I'm still using the stock speakers, amp, and have no issues at all with noise, so it shouldn't be a problem if you install it correctly. The RP5-GM11 is the most commonly used interface, another option (which is the one I have) is the GM1A-RST both made by PAC. The GM1A-RST is their latest, and has some advantages over the RP5 but it costs more. Both the RP5 and GM1A come with the AM/FM antenna adapter, so you won't have to buy one in addition. I've done the same thing you mentioned about running the USB cables to the center console, replacing the charging port, works good. Are you planning on adding the XM tuner ? If so, I can give you some guidance on reusing the stock XM antennas if you're interested. The stock XM tuner cannot be used, so you'd need to get the SXV300V1 tuner if you want XM radio,
but the stock antennas can be reused. Also, if you get an after market navigation system, (depending on the manufacturer), you can reuse your stock navigation antenna, it'll plug directly into Kenwood and I believe Sony uses the same connector, Pioneer uses a different connector which would require and adapter, I can make up the adapters for this myself, as I couldn't find anyone who makes them. I also suggest adding a rear backup camera and a front camera while you're at it, if the head unit you're looking at is multi camera capable. The front one helps to avoid hitting parking blocks, and the rear one helps with blind spots when backing up. Let me know if you have any other questions.
Thank you so much for all the tips and info! I have XM in my daily driver, but I don't think I'm going to put it in the Vette. I may change my mind later, but hopefully not. I am thinking about getting a Kenwood DMX9707S. I am also wanting to install a front and rear camera. I did look at the different interfaces, but for $100 difference in price, I think I am going to go with the RP5-GM11. I am already over what I wanted to spend!
One more question...hopefully only one! I received my new head unit today, a Kenwood DMX9707S. I also received the RP5-GM11 today. Although I won't have the other stuff I need for a few more days, I decided to wire up the harnesses and get the head unit ready.
I have the Bose system. My question is, do I need to connect all of the speaker wires from the Kenwood harness to the RP5-GM11 or do I not have to do that because I have the Bose system? I haven't removed the factory radio yet, so I don't know how everything is hooked up to it.
unkled20 (04-29-2021)
To masonp: I know this thread is old but I'm waiting for my Kenwood DMX 907S & SXV300V1 to come in and I would like to keep the factory antenna on my 2012 GS. What do I need to do or buy?
