Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-13-2002, 12:45 AM   #1
RedHot94
CF Senior Member
RedHot94's Avatar
Default Need recommendations - CD Changer for a 94 C4
I'm getting fed up with the Bose CD player not tracking (and I just had it replaced last year). I'm thinking of added a CD changer to the OEM setup. What would you recommend and where would you install the changer?
Thanks.
RedHot94 is offline   Reply With Quote
Old 11-13-2002, 09:53 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
Default Re: Need recommendations - CD Changer for a 94 C4 (RedHot94)
You will need an RF type of changer...
I would get a good changer. Alpine makes excellent changers. small, too.
where to put it.. good question...
you might fit an Alpine into the rear storage area behind the passengers seat.
bogus is offline   Reply With Quote
Old 11-14-2002, 09:59 AM   #3
92TripleBlack
CF Senior Member
92TripleBlack's Avatar
Default Re: Need recommendations - CD Changer for a 94 C4 (bogus)
If you are going to add a sub, integrate it into the sub box setup. If not, you could mount it in the storage compartment behind the passenger seat. You won't see it there and the install is relatively easy. You will need to run the wires to where you want the player. A constant+, ignition +, and ground. Also you will need to plug into the antenna. This is easily accessable under the carpet in the rear of the cargo area driver's side. There is a plug there you can splice into. It won't sound as good as your stock CD, which is a panisonic POS. GM contracted Panisonic to make the decks for the bose systems. Since it goes into the FM, it will only sound as good as a radio station, which has much less dynamic range than the CD on the deck. Even less highs and lows than the typical blose. I'd replace the deck with a dash changer or single CD and new speakers. It would sound much better and you could do replace everything for just a couple hundred more than an RF changer.
92TripleBlack is offline   Reply With Quote
Old 11-15-2002, 09:30 PM   #4
92PoloVette
CF Senior Member
CI 6-7-8-9 Veteran
92PoloVette's Avatar
Default Re: Need recommendations - CD Changer for a 94 C4 (92TripleBlack)
92PoloVette is offline   Reply With Quote
Reload this Page Need recommendations - CD Changer for a 94 C4
Tags
c4, cd, changer, corvette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
