C6 Chimes
Received 1,636 Likes
If you are replacing the factory head unit you can retain the door/warning chimes by using the correct wiring harness/interface for your car. I used the Pac Audio RP5-GM11 and it has it's own chime module to retain factory chimes.
Yes, that's what I have, but I read the instructions that some vehicles don't need it fitted. I was just fishing to see if anyone had done this and confirmed that the PAC chime was needed or not.
