Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-04-2002, 01:35 AM   #1
ScottiC5
CF Member
ScottiC5's Avatar
Default Unstable 12V Source in C5
Has anyone experienced inconsistent 12 volt source in your C5. My installer tells me that vettes have a notorious problem of having an unstable 12 volt power source. I have an ECLIPSE CD5442 and is frequently shutting down. The installer tells me that ECLIPSE are very finicky when it comes to power. The installer has tried tapping into different 12V sources and has been unsuccessful. It would be fine for a while but the gremlins return. :confused: :confused: Don't know what to do. May need to go back to the installer. Any suggestions appreciated.
ScottiC5 is offline   Reply With Quote
Old 11-04-2002, 02:56 AM   #2
Wicked C5
CF Senior Member
St. Jude Donor '04
Support Corvetteforum!
Wicked C5's Avatar
Send a message via AIM to Wicked C5
Default Re: Unstable 12V Source in C5 (ScottiC5)
Tell your installer to run a relay with the battery and the ign switch the problem should be gone after that. I am having a simler problem since I installed my clarion screen along with my Kenwood din unit
[Modified by Wicked C5, 12:44 AM 11/4/2002]
Wicked C5 is offline   Reply With Quote
Old 11-04-2002, 05:42 AM   #3
M396 #00-011
CF Senior Member
M396 #00-011's Avatar
Default Re: Unstable 12V Source in C5 (Wicked C5)
Quote:
Tell your installer to run a relay with the battery the problem should be gone after that. I am having a simler problem since I installed my clarion screen along with my Kenwood din unit
This should solve your problem.
M396 #00-011 is offline   Reply With Quote
Old 11-04-2002, 03:56 PM   #4
mike76002
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08
mike76002's Avatar
Do you have diagram to put in a relay?
I am ordering 0 ga wire to upgrade my charging system from Kale instruction and maybe adding the Relay to the batterry.
Thanks :cheers:
mike76002 is offline   Reply With Quote
Old 11-04-2002, 03:59 PM   #5
Wicked C5
CF Senior Member
St. Jude Donor '04
Wicked C5's Avatar
Default Re: Unstable 12V Source in C5 (mike76002)
Thanks :cheers:
I don't have the diagram but you can use a simple Bosch relay to install it. If you look on some car stereo sites I am sure you can find a diagram. Any good car stereo installer should know how to set it up
Old 11-04-2002, 04:18 PM   #6
mike76002
CF Senior Member
mike76002's Avatar
Where can you buy a Bosch relay? Autozone?
Is it called baterry relay?
Thanks :cheers:
Old 11-04-2002, 04:24 PM   #7
Wicked C5
CF Senior Member
St. Jude Donor '04
Wicked C5's Avatar
Go to a good stereo shop or even circuit city. The relay is about $5
Reload this Page Unstable 12V Source in C5
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
