I am undecided on head unit. Which alpine has the orange illumination?
As far as subs go - i'm not sure where to go with that. I dont want to take up all the rear room. The Stealthbox is cool, but i dont htink i can lean the seats back with it in there.
It is a standard cab right? I don't think you will be able to lean the seats back with anything you put in there. Unless you put a single sub on the passenger side and make your co-pilot suffer. :lol:
Focal 5wS Mini Sub (I know its not much spl but it will help, yes?)
This would be mounted in the center console under the arm rest.
The arm rest leans up, and there is a storage bin underneath.
I could fiberglass an enclosure out of it, and mount the 5WS there.
W:eek:W. That interior is quite a challenge for a stealth install. I may have to think about this one for a while. A question about your idea using the Focals in the center storage bin.....where are you going to allow the sound to come out at? I guess I'm just not seeing the whole picture yet.
.3 ported.
Hmnnnnnn..
Have you seen those tambourine subs? That would work...
Illusion Audio (cough, cough) used to make in inverted magnet sub. It worked very nicely in my old '97 blazer, crossed over at 100hz down in addition to the three way componet set really had a good front image presense, of course it didn't ring the ears like the 4 - 12's in the back!
How about removing the center console stuff, building a custom box with a downward firing 10" or a pair of 8"s and mounting the center console armrest on top. We did this on a caravan and it turned out great. Its hard to tell if you could from the pics and I've never been in one. Also, are the doors a possibility for subs?
