Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-03-2002, 02:48 PM   #1
lofarris
CF Senior Member
lofarris's Avatar
Default Best way to wire amp in C5?
I will start wiring my amp in a couple of days and I wanted to know if anyone has any advice before I start. To run the power wire I will probably drill a hole in the firewall and run it straight down the passenger side right under the door. What do I do for the RCA and Speaker wiring? Do I run it right under the door on the Driver side? I will be running three sets of RCA and 15awg speaker wire for the door speakers. Shoul I run it all together or separate the RCA and speaker wire, maybe run one down the center console? What is the best way to hide them without having a huge bulge in the carpet? I would also like to know how to ground the amp. I haven't done much research in the hatch (coupe) of my car, but I am guessing there isn't going to be a good ground easily available.
Thank you
lofarris is offline   Reply With Quote
Old 10-04-2002, 03:35 PM   #2
MY2K2C5
CF Senior Member
MY2K2C5's Avatar
Send a message via ICQ to MY2K2C5
Default Re: Best way to wire amp in C5? (lofarris)
You will not need to drill into the firewall. You can slip the power wire through the grommet. Remove the battery and you will see a grommet running into the firewall. Run your wire through there and down the passenger side. There will not be a bulge under the carpet.
Run the speaker wire and RCA wires together. I used the sticky sided zip tie mounts to secure the wires to the car. Lay the carpeting over the wires and you should not have a bulging problem. If you do you can seperate them a bit and use duct tape to secure each wire to the car at a reasonable distance along the routes of your wire runs.
Your ground wire can be behind the passenger side seat. There is spot that another component is grounded to that you can use. That will make a very short run for your ground to your amp mounting location.
You can run your wires behind the rear speaker mounting area and along the rear of the car if you intend to mount an amp in the rear area. If you are going to put an amp rack behind the seats and in front of the holders for the car top you can run your wires out where the two pieces of carpeting overlap. Tape them down to the body of the car and this will make it easier to work with them in the amp rack.
Hope that helps....
MY2K2C5 is offline   Reply With Quote
Old 10-04-2002, 05:40 PM   #3
MEATHOUSE
CF Senior Member
MEATHOUSE's Avatar
Send a message via AIM to MEATHOUSE
Default Re: Best way to wire amp in C5? (MY2K2C5)
the closest ground for a rear mounted amp is behind the drivers seat?????????? that can't be
justin
MEATHOUSE is offline   Reply With Quote
Old 10-04-2002, 08:29 PM   #4
MY2K2C5
CF Senior Member
MY2K2C5's Avatar
Default Re: Best way to wire amp in C5? (MEATHOUSE)
Behind the passenger seat... you are already running the hot down that side may go ahead and use the ground behind there....
[img]http://groups.msn.com/_Secure/0UgAAAFIbrE0UVh3hM8Eg5ZkhN3PxFpTj3rCgUJL 6nioMSZwpz3g6avb4U!ho8XlSXkhpaDd*NQYxsO2 ue823IAX3HgH5yo4WgRVQB2jZcHaTavOeHtEKJdD kEuVPiNmM/Car-Stereo-Installation-Pics-011.jpg[/img] :seeya
Reload this Page Best way to wire amp in C5?
Tags
amp, amplifier, c5, corvette, install, power, run, spot, vette, wire, wires
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C5 and general audio FAQ scott_fx Audio/Electronics 172 11-06-2011 10:25 AM
C5 Bose upgrade wiring notes 99HT Audio/Electronics 11 10-08-2011 05:45 PM
C5 Bose Upgrade Info 99HT Audio/Electronics 18 08-16-2004 04:02 AM
C5 Sub Install Help Needed!!!! Al '92 Audio/Electronics 9 11-26-2002 10:39 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
