Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-03-2002, 01:22 PM   #1
LuvmyC5
CF Senior Member
St. Jude Donor '05-'08
LuvmyC5's Avatar
Default Sub box question..........
Is there a formula, or some way to figure out the proper sub box volume (size), and how to size the sub. I'm very new to this audio stuff, but am pretty good with wood, so I thought that I'd give box building a try. Any info would be appreciated.
LuvmyC5 is offline   Reply With Quote
Old 10-03-2002, 03:24 PM   #2
M396 #00-011
CF Senior Member
M396 #00-011's Avatar
Default Re: Sub box question.......... (LuvmyC5)
Nothing special, just standard Volume equations. Length X Width X Heigth in inches. Take this value and divide by 1728, that will give you the cubic foot on the enclosure. By using interior measurement, ( or outside measurements minus the wall thinkness ) and also subtracting the subwoofer basket displacement, this will give you true interior volume.
M396 #00-011 is offline   Reply With Quote
Old 10-03-2002, 03:55 PM   #3
LuvmyC5
CF Senior Member
LuvmyC5's Avatar
Default Re: Sub box question.......... (M396 #00-011)
Old 10-03-2002, 09:54 PM   #4
92TripleBlack
CF Senior Member
92TripleBlack's Avatar
The real trick is using the correct box size. The maker should tell you the specs of how much volume you need. You may want to put ribs inside to make it stonger so don't forget to subtract them from your volume. Use MDF and Liquid nails to make it.
92TripleBlack is offline   Reply With Quote
Old 10-03-2002, 10:18 PM   #5
JoeyG
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
JoeyG's Avatar
Default Re: Sub box question.......... (92TripleBlack)
Totally depends on recommended box volume. Most "C5" construction cases fall to fiberglass and either mdf or birch composition, as well as liquid nail sometimes.
JoeyG is offline   Reply With Quote
Reload this Page Sub box question..........
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Group project building a C5 sub box vrumvrum Audio/Electronics 10 02-22-2003 01:56 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
