Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-29-2002, 06:11 PM   #1
lofarris
CF Senior Member
lofarris's Avatar
Default How much current consumption is too much for my C5?
I am looking for a five channel amp to run my whole system. I don't want to run more than one amp because I am afraid it will be too much of a strain on the electrical system. How much current drain is too much for a single amp in my 98? Also, any recomendations for a good low drain, multi-channel amp would be appreciated.
lofarris is offline   Reply With Quote
Old 09-29-2002, 07:33 PM   #2
ZippoMan
CF Senior Member
ZippoMan's Avatar
Default Re: How much current consumption is too much for my C5? (lofarris)
I believe even 2 amps is okay if you have a good battery. I don't know the numbers though.
ZippoMan is offline   Reply With Quote
Old 09-29-2002, 10:54 PM   #3
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
You should be ok if you don’t go over 500 to 800 watts, although, you may still get some light dimming. The problem is you have a 110 amp Alternator in the C5 and it is pretty much taxed to the limit with all the electronics in it. I would suggest you at least upgrade the electrical system wiring for the car.
The “Big 3” wires, just add this in addition to the stock wires.
Use at least 4-gauge Power wire and run from alt to battery pos. terminal.
Use at least 4-gauge Ground wire and run from battery neg. terminal to chassis and from engine block to chassis. That will certainly help a great deal for a minimal cost.
You might also want to eventually go with an Optima battery as well.
:cheers:
_Nomad_ is offline   Reply With Quote
Old 09-29-2002, 11:42 PM   #4
JoeyG
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
JoeyG's Avatar
Well in my experience (seriously though) :smash: anything under about 30 amps should be fine with the cable and battery/capacitor upgrade
Anything over 50 amps you'll need a higher rated output alternator if the stereo will be at moderate/high volume levels for long periods of time. :eek:
JoeyG is offline   Reply With Quote
Old 09-30-2002, 05:04 PM   #5
_Nomad_
CF Senior Member
_Nomad_'s Avatar
Default Re: How much current consumption is too much for my C5? (JoeyG)
I agree, ideally I would upgrade the alt. to at least 140 to 170 amp. You will also need to upgrade the "Big 3" wires like I mentioned in my earlier post and get a more stable battery such as an Optima Yellow Top (deep cycle). That would be the best course of action, however, if you just want to take it one step at a time since money may be an issue, then go for the electrical wire upgrade first (you will have to do this anyway if you upgrade the alt.) and perhaps a stiffening cap, depending on the system design.
Note: When upgrading the electrical system wire as described in my earlier post, remember to fuse the power wire from alt. to battery pos. terminal with an ANL fuse at what the alt. is rated at.
:seeya
Reload this Page How much current consumption is too much for my C5?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Ford GT CRANKSHAFT ISSUES!! ZO6 competitor? You can keep your Ford!!! 427 C5 C6 Z06 Discussion 60 03-09-2005 05:32 AM
Paging Lou G SPEED DOG C5 Tech 13 02-01-2004 05:38 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
