Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-28-2002, 09:45 PM   #1
ICULUKN-C5
CF Senior Member
ICULUKN-C5's Avatar
Send a message via AIM to ICULUKN-C5
Default where did you put your xm antenna
I was told that since I have a corvette, I would have crappy reception since there is no metal to relect the signal. Please tell me where you mounted, preferably stealth antenna. Also what antenna are you using.
ICULUKN-C5 is offline   Reply With Quote
Old 09-29-2002, 03:48 AM   #2
KylePatrick
CF Senior Member
KylePatrick's Avatar
Send a message via AIM to KylePatrick
Default Re: where did you put your xm antenna (ICULUKN-C5)
I'm using the TERK "mouse" looking antenna, mounted it on the dashboard wedged up next to the glass, on the passenger side, next to the pilliar, perfect reception, took a road trip from houston to san marcos (3 hours across tx) and had no problems with reception period. No antenna on the outside :)
Kyle
KylePatrick is offline   Reply With Quote
Old 09-29-2002, 12:56 PM   #3
ICULUKN-C5
CF Senior Member
ICULUKN-C5's Avatar
Default Re: where did you put your xm antenna (KylePatrick)
COOL..Did you have to do anything special to mount? The install shops locally are telling me that the signal wont go through tinted glass, anyone else have this problem.
Old 09-29-2002, 02:50 PM   #4
KylePatrick
CF Senior Member
Nope, its on the dash of the vette, I have 20% metallized tint on the car, all the way around :) It even works inside my garage, with the overhead door shut, kinda spooky.
Kyle
Old 09-29-2002, 08:19 PM   #5
JT-C6
CF Senior Member
Cruise-In IV Veteran
St. Jude Donor '03-'06-'08-'10-'11
Support Corvetteforum!
JT-C6's Avatar
This topic seems to come up every few weeks. The antenna will work through glass. It will also work through the non-metallic body panels. Since Labor Day, mine has been inside my rear fascia. Here is a picture of it as view from the inside. This picture was taken by putting the camera inside the drivers side tail light and pointing it towards the license plate area. The antenna is the Terk SR-2 (computer mouse style). It is sitting on top of the area above the license plate. Note the corvette lettering embossed in reverse view to get its approximate position.
It's a great stealth location and the reception is about as good as my external install on my pickup truck.
JT-C6 is offline   Reply With Quote
Old 09-29-2002, 08:29 PM   #6
BigByrd
CF Senior Member
BigByrd's Avatar
ICU -
Yep! The dash is the way to go. Although the Turk 'turtle' will pick up through the rear facia, and, agreed it is 'stealth' that way, radio signals are strongest in line-of-sight installations. Your reflective window tint will have some adverse effect. Perhaps prior to a final committment, I suggest you place the 'turtle' on the dash to hear the reception. If you experience too many drop-outs you can then try another location.
My dash install works fine. Sure, it is noticeable but it nestles up nicely next to my Crystal tweeter's. Although I have changed radio HU, check out my site for pics.
You'll really like XM . . . :seeya
P.S.
Delphi is coming out with a hand-held XM about Xmas!
BigByrd is offline   Reply With Quote
Old 09-29-2002, 08:50 PM   #7
KylePatrick
CF Senior Member
Default Re: where did you put your xm antenna (JT-C5)
Just out of curiosity, whats the easiest way to get it into rear facia area?
Kyle
Old 09-29-2002, 09:15 PM   #8
BigByrd
CF Senior Member
BigByrd's Avatar
Remove a rear tail light.
Old 09-29-2002, 10:37 PM   #9
dexter
CF Senior Member
dexter's Avatar
Location: Did you know that the "B" in Benoit B. Mandelbrot stands for 'Benoit B. Mandelbrot'?
I had mine installed yesterday, they put a Sony mouse type (looks very much like the Terk antenna) mounted between the seats at the very front of the cargo area. Reception so far seems great - it's funny that the big buildings downtown don't seem to affect reception, going through tunnels doesn't (unless it's a long tunnel), but going under trees seems to result in an immediate cut out of a few seconds. Oh well. The sound quality is outstanding and the channel lineup seems endless.
All in all: :D :D :smash:
dexter is offline   Reply With Quote
Old 09-30-2002, 07:05 PM   #10
JT-C6
CF Senior Member
JT-C6's Avatar
Default Re: where did you put your xm antenna (dexter)
I can only speak from experience on the coupe. I took a taillight out which is just 2 screws and about 30 seconds worth of effort. I ran the wires from the coupe cargo area around the carpet under the weatherstripping in of the rear deck lid and down a drain hole into the fascia. You could easily run this wire in about 10 minutes or less.
I don't want to see the antenna at all. The windshield/dash mount idea is great, but I want this to be as stealth as possible. It works fine. The only thing I may try to increase reception is to put a metal plate under the antenna of some length to get a better reflective ground plane. As previously mentioned, I get the same reception from the aerial mounted antenna on my truck.
Reload this Page where did you put your xm antenna
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Best XM setup for C5? sandmanusd C5 General 25 08-09-2005 04:21 PM
Are you SIRIUS? (satellite radio) Prosecutor C5 General 16 03-05-2005 09:33 PM
C6 Vert Review with S2K Comparison: Warning---Epic length! S2K C6 Corvette General Discussion 47 02-27-2005 01:08 AM
Satlite Radio? 02 batmobile C5 Z06 Discussion 22 11-24-2004 02:31 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
