Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-21-2002, 07:11 PM   #1
rrobert22
CF Senior Member
rrobert22's Avatar
Default Help with amp and speakers!
Ive done some research and It looks like I will have to add an amp to replace the front speakers if I want any sound. I was looking at a 6 1/2 inch seperates system from MB Quart, just their middle of the road separates. I would like to spend around 300$ on speakers and the same on an amp. Unsure of which amp to get, I used to use PPI amps a LONG time ago when I was into car sterios, with MB quart and JL subs. I see guys putting in 8 inch woofers, and was wondering what other speakers I should match that with up front if I decide to go that way. Any suggestions appreciated. :cheers: Also I want to mount the amp in the rear CD compartment, If I run the wires that far, will I suffer any signal degredation, or noise?
rrobert22 is offline   Reply With Quote
Old 09-21-2002, 07:18 PM   #2
Kale
CF Senior Member
Kale's Avatar
Default Re: Help with amp and speakers! (rrobert22)
For $300 look at the JL XR650's, Crystal Diamond, and Focal Polyglass
Kale is offline   Reply With Quote
Old 09-21-2002, 07:33 PM   #3
rrobert22
CF Senior Member
rrobert22's Avatar
Default Re: Help with amp and speakers! (Kale)
Will those work okay in the stock location? I found some for 259$ thats not too bad, I am looking at the PPI PCX-280 for the power, how does this combo sound to you guys? :cheers: Thanks for your help :cheers:
Old 09-21-2002, 07:59 PM   #4
Kale
CF Senior Member
Kale's Avatar
US Acoustics will give you sound quality that will match $300 componetns for a great price
http://www.thezeb.com
Old 09-22-2002, 01:13 AM   #5
rrobert22
CF Senior Member
rrobert22's Avatar
Ill check it out :D Thanks :cheers:
Reload this Page Help with amp and speakers!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
I need help with C5 stereo. Changed rear speakers and volume is to low. 74-Roadster Audio/Electronics 14 03-11-2004 06:29 PM
Help choosing amp... KamloopsZ06 Audio/Electronics 15 08-08-2003 05:21 PM
amp and speakers jtfrog Audio/Electronics 10 06-30-2003 03:53 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
