Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-18-2002, 10:43 PM   #1
lofarris
CF Senior Member
lofarris's Avatar
Default How do I stop the rattle in my C5 doors?
Has anybody put any dyna mat or other sound deadning material in their doors. I have a real bad rattle in my door, which I think is acually the window. When I took off the door panel I realized their really isn't anything else that could be rattling.
I would also like to know if it would be wise to put some dyna mat underneath the carpet in the hatch? Will if be very effective in cutting out road noise?
Any suggestions would be greatly appreciated.
lofarris is offline   Reply With Quote
Old 09-18-2002, 11:39 PM   #2
JoeyG
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
JoeyG's Avatar
Default Re: How do I stop the rattle in my C5 doors? (lofarris)
Depends. Could be loose speaker plate, loose window track, lose, get the piont only observation and research will truely tell.
It will help more than you realize, road noise will aways be a problem, bu the addition of sound deadening material will greatly enhance clearer thoughts and conversation, so to speak. :cheers:
JoeyG is offline   Reply With Quote
Old 09-19-2002, 01:18 AM   #3
_Nomad_
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11
_Nomad_'s Avatar
Location: Frankenstein never scared me. Marsupials do, because their fassst…and they DART, THAT'S crazy!
Default Re: How do I stop the rattle in my C5 doors? (JoeyG)
Like said above tracking down rattles is trial and error, however, there are some rule of thumb thing you can do to reduce rattles and by doing so may just knock out the rattle you have in the process.
First, sound dampen the doors, don’t waste your money on Dynomat, look into something like B-Quiet “Brown Bread” or Rammat. These two products work just as well as Dynomat extreme and for a fraction of the cost. You can read up on Brown Bread here:
www.b-quiet.com
After using about 3 to 4 layers of sound dampening material on the doorframe. Put a ¼” piece of either carpet padding or “egg crate” foam (the stuff you put on beds to make then softer) in-between the door panel and the doorframe. Also make sure the speaker grill is on tight, it is just attached with little tabs that are bent around slit in the door panel and can be loose if not checked. Then remove the Bose emblem on the speaker grill and reattach it with double-sided tape to eliminate that as a potential rattle.
I would also recommend sound dampening the entire car with about 4 layers of Brown Bread or other sound dampener but if you just want to do the rear hatch area, that too will greatly reduce exterior sound from entering the car as well as reduce resonant frequencies and increase SPL inside the vehicle.
If after all of that you still have rattles then you my friend are cursed with a gremlin and I don’t envy your ensuing hunt for it.
Good luck.
_Nomad_ is offline   Reply With Quote
Old 09-20-2002, 10:39 PM   #4
lofarris
CF Senior Member
lofarris's Avatar
Default Re: How do I stop the rattle in my C5 doors? (The^Nomad)
I have tried to find somewhere that stocks be-quit in my area but haven't had any luck. I think I am going to go with the dyna-mat because it is sold everywhere. Will it be to thick to put on the backside of my door panel?
Old 09-21-2002, 12:07 AM   #5
_Nomad_
CF Senior Member
_Nomad_'s Avatar
Just check Ebay for Brown Bread, it is all over the place there for excellent prices.
Or you can go here:
www.b-quiet.com
Yes, you can put the dampener on the inside of the door panel.
Reload this Page How do I stop the rattle in my C5 doors?
Tags
c5, corvette, door, rattlein, rattling, stop
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
