C6/C7 Molded ABS door speaker adapter plates now instock and shipping!
Former Vendor
I now have the front door speaker adapter plates instock and shipping.
These are ABS molded plastic and what you will need to use to convert the front door speakers
on all 2005-2016 C6 and C7 Corvettes to a component speaker setup.
$17.99
Looks great, What speakers do you recommend for a replacement of the factory 2016 Z06 door speakers? any such animal? would like to pull out the crap speaker and plug in something better? what is available? Thanks.
Former Vendor
If you wan tto swap adding amps speakers subs ect then these will work and we can set you up with a package deal.
You can cut the wiring from the stock connectors if you like and add new replacement 3.5 and 5.25 as another option
