Where to mount tweeters on early C4?
I plan on buying a set of alpine 136a component speakers and need to decide where to mount the tweeters. Thanks again!
Re: Where to mount tweeters on early C4? (JOHNL)
if you eliminate your breadbox yuo can hang them under the dash cap at a 45' angle towards the opposite passenger.
Re: Where to mount tweeters on early C4? (Audiowizard)
Dash, a pillars, or doors with the mids in the doors. Dash is the stealth way to do it without cutting. Doors will have cutting or perforating. A pillars, which is where I have mine, aren't as stealthy. I would do the other two but I don't have dash locations and the door panels cost to much to cut.
