Diamond Audio Amp and Amp rack C5 Package deal $250.00 shipped
Former Vendor
I have these brand new Diamond Audio amps with an amp rack build for them ready to go for someone.
$250.00 shipped
This is for a C5 fitment.
Was ordered then cancelled
Amps are
Diamond TX4001
Diamond TX3004
Features:
TX Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 50 watts x 4 chan.
2 ohms: 75 watts x 4 chan.
Bridged, 4 ohms: 150 watts x 2 chan.
Pulse Width Modulated MOSFET power supply
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +12 dB bass boost at 50 Hz)
4/3/2 channel operation
Speaker level inputs
Preamp RCA outputs to daisy chain multiple amps
3-way protection circuitry (thermal, overload, and speaker short protection)
High efficiency thermal convection heat sink
Nickel-plated RCA level inputs
Nickel-plated, low resistance power and speaker connector blocks
Input sensitivity:
Low level: 150mV-5V
Variable high-pass filter (50-250 Hz, 12 dB/octave)
Variable low-pass filter (50-250 Hz, 12 dB/octave)
Frequency response: 20-20,000 Hz
Dimensions: 13-7/16"W x 8-3/4"D x 2-5/16"H
Specifications:
Amplifier Class AB
Number of Channels 4
Total RMS Power Output 300 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.02%
Speaker Level Inputs Yes
Preamp Outputs 1 pair
Built-in Crossover LP / HP
High-Pass Crossover Frequency 50 - 250 Hz
Low-Pass Crossover Frequency 50 - 250 Hz
Signal-to-Noise Ratio 90 dB
Channel Separation 90 dB
Bass Boost 0 - 12 dB
Bass/Gain Remote No
Fan Cooled No
Fuse Rating 20A x 2
CEA-2006 Compliant No
Strappable No
Features:
TX Series Monoblock Class GH Car Amplifier
RMS Power Rating:
4 ohms: 275 watts x 1 chan.
2 ohms: 450 watts x 1 chan.
1 ohm: 600 watts x 1 chan.
Wired remote bass level control included
Variable Bass Boost (0 to +12 dB bass boost at variable frequency 30-125 Hz)
Input sensitivity:
Low level: 150mV-5V
Variable low-pass filter (50-250 Hz, 24 dB/octave)
Phase Shift: 0-180°
Subsonic filter (Variable)
Dimensions: 13-3/4"W x 8-3/4"D x 2-5/16"H
Specifications:
Amplifier Class GH
Number of Channels 1 - Mono
Total RMS Power Output 600 watts
Minimum Impedance Unbridged 1 ohms
Minimum Impedance Bridged Not Bridgeable
THD at Rated RMS Power 0.01%
Built-in Crossover Low-pass (LP)
Subsonic Filter 16 - 60 Hz
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 40A x 2
Strappable No
$250.00 shipped
Amps are
Diamond TX4001
Diamond TX3004
Features:
RMS Power Rating:
Input sensitivity:
Low level: 150mV-5V
Specifications:
Amplifier Class AB
Bass/Gain Remote No
Fan Cooled No
Fuse Rating 20A x 2
Strappable No
Features:
RMS Power Rating:
Input sensitivity:
Low level: 150mV-5V
Phase Shift: 0-180°
Specifications:
Amplifier Class GH
Fan Cooled No
Fuse Rating 40A x 2
Strappable No
