Is this a suitable ground? ... alternator whine
Navigator
In my 08 non bose I had an Alpine INE-S920HD using the GMOS harness with no issue. I removed it and installed in my new 12 with bose and added a ASWC to the wiring (this has 3 more wires that are added to the ground). Now that it is installed in the 12 I have alternator whine that I did not have before. I am assuming this is a ground issue? I removed the ASWC from its plug effectively removing its wiring from the equation I think with no change.
Should I run a new ground for the head? Should I ground the head by itself or should I ground it and the GMOS and ASWC all together?
Finally for maybe the dumb question... if I make a new ground not sure how easy it would be to get to the firewall but would this screw under the console by the heated seat switches work effectively?
Navigator
Well I regrounded everything to a screw to the left of the dash I found mentioned in another thread and still getting noise when the car is running. Might be a bit less but still there.
Navigator
I assume for either of those options I need to cut up the wiring and splice in rcas somehow? Currently I am not using rcas as the gmos uses the speaker level outputs.
Navigator
Here is another question the steering wheel control adapter has three wires that go to the ground, the gmos has one, the parking break bypass has one, the relay has one and the radio has one. I combined all the harnesses to a single ground and the relay and the radio to a second. I then grounded them all to the same bolt. The local shop said to try splitting them up to different locations but that seems counterproductive and would increase possibility of a loop would it not?
If it doesn't work or you don't like what it does to the sound you can just unplug the adapter and you're back to normal.
What SWI do you have that needs 3 ground wires
Navigator
Thanks for all the info....
I took the radio and relay and grounded to one location, and then the others to another with no noticable change.
As for the SWI, I have the Metra ASWC. And while not technically 3 ground wires the instructions say to put black to ground as well as connect the White/Green wire and the Green/Orange wire of the ASWC to chassis ground.
http://contentdocs.installernet.com/...icle/12422.pdf
The noise I have is not extreme but definately there.... do you think a noise filter like this is worth a try? http://www.crutchfield.com/S-Bq55hZH...-250-watt.html
