FS: Like New Cadence S1W8-D4 8" Sub
For sale is my slightly used 8'' Cadence subwoofer.
I used it as a factory sub replacement. I played it for
30 minutes then used a different box. Works great.
$65 shipped
Paypal accepted.
PM me with any questions
This a a stout little sub. Great for a 150-300 watt amp.
Product Description
8" Subwoofer
Specifications
RMS Power Handling: 250 Watts
PEAK Power Handling: 500 Watts
Frequency Response: 28Hz - 750Hz
SPL @ 1w/1m: 90dB
System Impedance: DVC 4-Ohm
Magnet Weight: 15 oz
Structure Weight: 30 oz
Cutout Diameter: 7.50"
Mounting Depth: 3.70"
Features
• “M” Style Double Laminated Foam Surround for High Speed Bass Response
• Expanded and Rolled Steel Basket
• Magnet Motor Heatsink with Heat Pump Cooling Technology
• Aero Style Overized Magnet Motor Vent
• Quad Layer Linear Progressive Conex Spiders
• Integrated High-Current Tinsel Leads
• Black Aluminum 4 Layer Voice Coil
• Ultra Saturated, High “BL” Magnetic Motor Gap
• One Piece Extended Pole Technology
• Oversize Double Laminated Stitched Surround
• Dual Nickel Plated Spring Loaded Push Terminals
• Fiber Reinforced Ultra-Stiff Paper Composite Cone
• 3-D Injected Poly Dustcap
• Stylized Protective Rubber Magnet Boot Cover
• Molded Plastic Trim Gasket
Configuration Options
• 2 Ohm in Parallel
• 8 Ohm in Series
