Sponsored by: DashLynx
Old 03-25-2015, 01:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Android Head Unit & Backup Camera Installation
Old 10-10-2016, 09:41 AM
  #381
bjmsam
bjmsam's Avatar
Originally Posted by 383
I've tried 4 different elm's and although they're cheap I'm done tossing money at this thing. I'm just looking for confirmation that they actually work
Well, I stand by my recommendation on page 1 of this thread.
Old 10-10-2016, 10:00 AM
  #382
383
383's Avatar
hmmm. That way the 1st one I tried but only connects 10% of the time after 10+ attempts. The one I got was red though .... Ill have to Look into what one I actually got.
Old 10-10-2016, 10:36 AM
  #383
bjmsam
bjmsam's Avatar
That is the OBDLink MX Wi-Fi. My OBDLink MX Bluetooth connects 100% of the time.
Old 10-25-2016, 06:38 PM
  #384
TheSenator
TheSenator's Avatar
Joying has new 2gb RAM and 32GB memory units on the way to the market. Shipping says ETA of late November.
Guess my 1gb unit will be right back on the shipping truck back to Amazon...
Old 11-02-2016, 09:22 PM
  #385
TheSenator
TheSenator's Avatar
Can someone who has used the OS2X module, tell me how they wired up the SWC wires?
EDIT: I found the GR w/WH wire and the Yellow (battery) on the PAC harness. I re-read the 1st post and it says to wire the gr/wh wire to KEY 1, but then the yellow to GND lead. Shouldn't the yellow be hooked to ACC +12v?
Old 11-03-2016, 04:52 AM
  #386
bjmsam
bjmsam's Avatar
You might be confusing PAC side vs. connector side of the two cut PAC harness wires.
The PAC has two types of steering wheel control (SWC) connections; a mini phono jack and a single blue/yellow wire. It also has a 10-position switch that determines SWC signal compatibility with mainstream HUs. This HU has two wires labeled KEY1 and KEY2 and according to the documentation works with only resistive signals like the Corvette's (see Volume 1 of the shop service manual for schematic). I tried the single wire, and I cut off the phono jack and tried the red and white wires, and I tried all ten switch settings, but nothing worked and I couldn't make sense of the PAC SWC signals with my multimeter. I solved it by cutting the yellow and green/white wires from the PAC that correspond to the purple (6) and dark blue (7) wires from the car and connecting them to the KEY1 and GND leads from the HU. The HU immediately recognized the buttons and made it easy to map them to the desired functions (my 1-6 button now controls mute).
The PAC harness brings its power in on the yellow wire and loops it back out on pin 6 to power the car SWC (purple wire on the car side of the connector). I believe yellow is constant power rather than switched, so I didn't care for that approach anyway (why energize the car SWC resistor tree when the ignition is off?). Cut that loop and connect the outbound yellow wire on pin 6 to the KEY1 wire. The SWC circuit becomes:
HU KEY1 <--> connector side PAC yellow pin 6 <--> car SWC purple pin 6 (+)
HU GND <--> connector side PAC green/white pin 7 <--> car SWC dark blue pin 7 (-)
TheSenator (11-03-2016)
Old 11-03-2016, 10:59 AM
  #387
TheSenator
TheSenator's Avatar
Thanks!!! You are correct, I was backwards. After the drive from NOLA to Houston yesterday, my brain was apparently not functioning properly. The last quote was exactly what I was missing.
Sidenote - the new 2GB RAM and 32GB Flash Joying unit is FAST. Very Fast. I got everything else wired in and was able to play around a bit with the unit. UI is good enough, and I can't wait to pair my MX I had from my truck.
Old 11-07-2016, 05:12 PM
  #388
CitznFish
CitznFish's Avatar
Received 1,354 Likes on 483 Posts
Bookmarked for my installation attempt this weekend
and with a backup camera
I've never installed a car stereo in my life. I've researched how to do this and bought all the items needed (PAC module, ground loop isolators, Double din installation kit. I imagine this 3 hour job will take me at least 8.
Pretty excited to update the stereo on my C6..
Old 11-07-2016, 05:17 PM
  #389
CitznFish
CitznFish's Avatar
Shoot. I just ordered a cheap-o 1GB unit from Corehan. ($197.00) I wonder if it is worth it to return and get this other one instead.
Old 11-07-2016, 08:27 PM
  #390
Naldinator
Naldinator's Avatar
Not that hard. Don't be a fool like me and cut off you PAC adapter rca jacks. Still do not know what I was tinkling there.
Old 11-08-2016, 12:27 PM
  #391
CitznFish
CitznFish's Avatar
LOL, I actually read your posts about that the other day. I will definitely leave those as-is.
Old 11-13-2016, 08:41 PM
  #392
CitznFish
CitznFish's Avatar
Spent about ten hours doing the entire job. Never installed an aftermarket radio before. Love having Waze, Spotify, and the beck up camera. The unit came with a usb on a long cord, wasn't sure what I was going to do with that. That's the only thing I think I could have done a little better if I had the proper tools.
Old 11-17-2016, 03:27 AM
  #393
Z2Z
Z2Z's Avatar
Looks great! I took one USB and ran it into the sender console and ran the other one into the glovebox.
Old 12-10-2016, 05:33 AM
  #394
bjmsam
bjmsam's Avatar
Originally Posted by Minkster
Seen this in several posts, a few questions:
Those are among the questions answered in more detail earlier in this thread for the model I installed in 2014 as well as newer models installed by other members of the forum, but to summarize briefly:
-Can you use an adaptor to connect to the OEM GPS antenna?
yes
-Where do you download or acquire updated maps for the SD card?
depends on the nav app that you choose
-How much area does the SD card maps cover, do they have POI's etc?
iGo and Sygic are among the options that have offline maps and POIs with worldwide coverage
-Can this be used without having a smart phone or data plan?
yes
-Can it display directions on the HUD, and/or voice commands?
no HUD directions, voice commands depends on the nav app that you choose
-Bluetooth for a cellphone, and can you use the vehicles OEM mic?
yes bluetooth, I have seen posts on use of the OEM mic in other threads, but I use the HU's mic
-Sound quality?
mine is wired to the OEM amp and speakers and sounds at least as good as the OEM HU (and offers far more options for equalization and other acoustic customization)
-USB?
yes
Old 01-05-2017, 07:12 AM
  #395
dreskiluv
dreskiluv's Avatar
Man this was great reading and explanation w/pix only wish this was for Iphone (almost makes me want to get Android "almost")
Old 01-05-2017, 08:11 AM
  #396
*El Ocho*
*El Ocho*'s Avatar
yeah,I don't think Apple is making head units yet, lol.
But as an iphone user (which I love), I have to admit that I'm happy with my Android HU.
Old 01-05-2017, 09:05 AM
  #397
bjmsam
bjmsam's Avatar
I'm not sure what is meant by "for Iphone." It is Android but works with Android, iPhone, Windows Phone, etc.
To Android Head Unit & Backup Camera Installation
Old 02-16-2017, 06:12 PM
  #398
bjmsam
bjmsam's Avatar
I remain so pleased with the Android head unit that I installed in my C6Z nearly three years ago that I just bought another one, this time for my 2009 Toyota Rav4 Sport V6. These are improving all the time... this one (C1067106A3 from "BonRoad") has double the CPU cores, twice the RAM and ROM, higher resolution, custom form factor and plug-and-play installation (took less than 30 minutes total), all for only $287. Impressive!
Last edited by bjmsam; 02-18-2017 at 08:32 AM. Reason: Wow, it has been not two years, but three!
Trios (02-17-2017)
Old 02-17-2017, 12:27 PM
  #399
Trios
Trios's Avatar
I remain so pleased with the Android head unit that I installed in my C6Z nearly two years ago that I just bought another one, this time for my 2009 Toyota Rav4 Sport V6. These are improving all the time... this one has double the CPU cores, twice the RAM and ROM, higher resolution, custom form factor and plug-and-play installation (took less than 30 minutes total), all for only $287. Impressive!
Is it instant-on yet or still a ~30 second boot time?
Old 02-17-2017, 01:35 PM
  #400
bjmsam
bjmsam's Avatar
Android still must boot, which happens a bit faster on this unit (closer to 20 seconds). As with the older unit in my C6Z, only the backup camera is available immediately (presumably because the OS is bypassed for that function). It's particularly annoying in this case because the Rav4 cuts power long enough to force a reboot when switching from ACC to START to ON. I am preparing to add a capacitor and diode to keep it running for a few seconds when power is cut; perhaps a similar approach could be employed to anticipate the need to boot when entering the vehicle (e.g.- tie in to the dome light circuit)...
Quick Reply: Android Head Unit & Backup Camera Installation
