Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-24-2002, 11:25 PM   #1
rxalot
CF Member
rxalot's Avatar
Default 94 Radio Replacement
I am deathly afraid of yanking plastic trim pieces, fear of something breaking. I would appreciate info on how to remove the front plastic trim with no to minimal damage, specifically where the attachment points are and if there are any screws.
I have joined the Bose haters club (previously a Bose home hater, now a car hater).
Thanks ahead.
rxalot is offline   Reply With Quote
Old 07-25-2002, 01:00 PM   #2
92TripleBlack
CF Senior Member
92TripleBlack's Avatar
Default Re: 94 Radio Replacement (rxalot)
Yours is slightly different from mine but I believe has the same screw points.
2 screws under felt/carpet liner in center console. Peel the corner's up to expose screws.
1 screw under ashtray
Lift the piece around the shifter exposing two screws on the bottom of the dash piece. Remove those screws.
Remove vent above radio-2 screws
Remove screw behind vent.
This should free the dash piece except for a clip or two and it should just pop out.
Last, don't be to afraid. Replacement for this piece is still available from GM. The one for my car is $35 so it can't be that much. I keep all the screws in the ashtray cup so I don't loose any.
Good luck. :smash:
92TripleBlack is offline   Reply With Quote
Old 07-25-2002, 08:21 PM   #3
rxalot
CF Member
rxalot's Avatar
Default Re: 94 Radio Replacement (92TripleBlack)
Thanks for the info. You were correct that there was a difference.
2 screws removes the top vent
4 screws remove the center console compartment door
3 screws remove the center console (including the one under the ashtray)
3 screws remove face plate (there is also one push connector mid way on the left)
Of course, now I am really beginning to hate Bose. The Scosche adaptor connects to the remote module in the storage compartment. So now I have to run some wires from the front to the storage compartment, including an extended antenna wire.
It's never Cheap, Easy, or Quick.
92TB, again thanks for the response.
Reload this Page 94 Radio Replacement
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Clutch replacement, few ?????'s James94LT1 C4 Tech/Performance 21 08-27-2010 02:25 PM
FS [TX] '94 dark red metallic coupe, testing the waters for possible sell Thanatos69 C4s for Sale/Wanted 12 12-01-2003 04:59 PM
Which would you buy? 92 or 94? EddieVetter C4 General Discussion 28 12-10-2002 06:15 PM
94 coupe install tips jsquared94 Audio/Electronics 10 11-07-2002 12:17 PM
What are the Disadvantages of Getting a 91-2 Z over 94-5? LowFlight C4 ZR-1 Discussion 13 02-19-2002 10:23 AM
SYS and battery GlockLT4 C4 Tech/Performance 10 08-14-2001 10:25 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
